Back to:
Tags:
Fuji Pictrography 3500 Printer
Printer error code (by 2 users)
posted by Sayyaf on Nov 11, 2007
Hi , I have a Tally Genicom 8008 colour laser printer that is giving a "SVC F5 error" on power on.
I believe the correct drivers are installed for XP and the PC finds the printer on USB.
Have looked thru the manufacturers web site and nothing on the SVC errors, except contact manufacturer.
Any ideas ?/
regards
john
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by sully1704, posted on Jan 08, 2008
svc f5 error when warming up but closes down when paper fails to feed into tally t8006. have checked there is no paper blockage.
Any help as I cannot find the meaning of the error and the machine is well out of warranty?
Best Solution
posted on May 23, 2008
Helpful (85)
Bogget
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
That code is nothing to do with the PC its the clutch on the OPC belt drive, poor connection or damaged clutch
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Printer error code:
I don't want to Accept this solution
Solution #2
posted on Jun 16, 2008
Not Rated (0)
moffit01
Rating: 0%, 0 votes
At the bottom of the OPC belt you can 'flip' 2 clips to release the waste feed assembly. I dismantled this and cleaned the connections onto the rollers - Cured the problem & much ceaper than a new belt.
Thank You!
Solution #3
posted on Nov 11, 2007
Not Rated (0)
osborne382
Rank:Wiz Wiz
Rating: 80%, 250 votes
Unistall it and reinstall it. If that fails....how old is the PC and whens the last time you had it serviced?
Thank You!
Can you Help with these Printers problems?
just recently purchased the fujifilm ask 4000 printer off...
Anyone know what the 'H76' error code means on the...
My 3500 is unusable at the moment.Problems started when...
I was using my printer today, and were printing lots of 6...
I bought a 3500 off of ebay plug it in and got a message...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
