Question about Behringer EUROPOWER EP2500 Amplifier
Behringer amp Hi, I have recently brought a Behringer EP2500 amp but when doing a gig last night it kept clipping the music. I have 2 x 400 bass bins and 2 x 400 top speakers. In the end I removed the bass bins and was only playing through the top speakers but still it clipped a couple of times. At the moment I have been using the parallel mode throgh both channels. Beginning to think I haven't set it up correctly but I'm not too good with manufactuers jargon! I would be very grateful to anyone who can explain what my setup should be in plain and simple terms.
  • avss1951 May 03, 2008
    I bought behringer EP2500 at Raon but then I just used it 3 times then it keeps on clipping until left channel stops and overheat (very hot). what is the common defects of this EURO technology????
  • 52 Answers
Hello pare ko.
EP2500 is a pro amp, manufacturer says that. Notorious to me.
Got 5 of these for repair. Clip is of course cause by too much
signal from source. If the amp is still clipped or on protect even w/out
signal in, time to open and do repairs inside. usually a MOSFET
inside P50N06 (50V-60A) is kaput. or MJE15033G and MJE15032G.
Now if blowing main Fuse, main txistor 2SA1943/2SC5200 maybe gone.
Read carefully the setting of your dip switches setting at the back.
This amp can drive 750 watts/ch@4 ohms.
Good Luck From Siliconchip
Posted on Sep 11, 2008
You try other brand like crown or QSC power amplfier they are the best rather than behringer
Posted on Apr 27, 2008
the amp you have (assuming it is working properly) is a high power proffessional amplifier which should be able to handle your speaker easily.
However the amp only amplifies the signal it gets: It seems to me as if you fed the amp with a distorted signal comming from the mixer (or whatever source).
For the setup of the amp:
- limiter off (for the sake of testing, if all OK these these on again)
- parallel or bridge mode off !!!!!!!! Use the 'normal' speaker out posts then
- check if input signal is distorted
- subsonic filters can be in
Posted on Dec 21, 2007
    Scholar:
  • 31 Answers
Clipping is caused by too loud a signal for the device to handle....this can be seen by connecting a signal generator to the input of an amplifier then reading the output signal across the speaker terminals with an oscilloscope...when the signal is being clipped the out put signal instead of a nice round curve at the top (or bottom) of the signwave instead its just a straight horizontal line..
I wonder if the amp you purchased is capable of the output sound you expect....the speakers sound like they are very powerfull and can handle the output signal OK, but just maybe the amp has a fault....which is causing the clipping.....
The amp needs to be tested by someone with test gear to ensure its capable if its 200 or (300-400watt) rating...
Maybe any pre-amp you are using has the same type of fault????
Cheers From YUBEUT
Posted on Nov 16, 2007
  • adfv Apr 24, 2011
    If you used this amp in bridge mode, clip limiter and hi pass filter (subsonic cutoff) should be turned off, and gain pot of the second channel set to 0 (full left). This can cause cliping and even overheating problems.
    But, this amp is too weak to drive 4 speakers of this power, i would get another one and drive subs in bridged mono (4 ohms - cca 2000W), and this one would drive tops at stereo mode (2x450w), or even better in bridged if you dont need stereo. This would rock the house.. :)
What number on each channel on behringer ep2500 to set for behringer vp1220 speakers
It is best to start with the mark on the ep2500 directly up (12 o'clock position). Gradually increase the output on your mixing board (MAIN MIX) to get desired volume. I you find that you're getting close to -10 to 0 dB, then start increasing the volume knobs on the ep2500. Watch for clipping on the amp.
Oct 11, 2012 | Behringer Ep2500
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
Europower Behringer EP2500, clip lights turn on when main power is off
Depending on the age of the amp,there is a possibilty that the amp my have damaged lanes or tracks to the pre-amp section to the front of the amplifier.
May 29, 2012 | Behringer EUROPOWER EP2500 Amplifier
Clipping the channels
The manual discusses the Clip Inidicator and how to deal with clipping.
Clipping in this amp isprimarily a function of the input signal being distorted so the input level is recommended to be lowered. Beyond that the cause of input distortion would have to be addressed in the device producing it.
http://www.retrevo.com/support/Behringer-EP2500-Amps-manual/id/23281ci655/t/2/
Dec 30, 2010 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 Clip light Channel 2 stays on & heatsink HOT!
There are so many components that can fail that troubleshooting this can be an expensive problem.
HINT: Put a 150 Watt light bulb in series with the power going into to limit current for/during troubleshooting.
Go through and compare the voltages on the teo channels. If power amp transistors have failed, likely the driver transistors also are gone.
Testing components in-circuit is very dificult. Resistors are pretty reliable and usually show damage by discoloration.
Furhter use before repairing MAY cause further damage.
Jun 03, 2010 | Behringer EUROPOWER EP2500 Amplifier
Behringer ep 2500
if after the pop it smells like a firecracker just went of than you fried the circit for that speaker or if it has fuses on it or ferther down the wire check them but it could be just the radio and nothin to worry about:)  a friends car does it, and it is very anoying
Jun 01, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
493 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
