Question about Car Audio & Video
Keyles door entry
I have a 1999 siluhoute I have replaced the battery and tryed to reset it by holding the lock and unlock buttons in at the same time but it still dont`t work and I checked the fuse in the van. Where do I check next
  • SOMA REDDY Jan 14, 2008
  • 306 Answers
Do you have warranty on the car still? I would take it to the dealer ship and have them fix it for free if possible.
Posted on Nov 11, 2007
I am trying to program my remote key fob but my Data Link Port does not have a metal contact pin in slot #8. What can I do to connect 4 and 8 as instructed?
Transmitter Programming
Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds. The locks will again cycle once. Repeat step #2 for each additional keyless entry transmitter. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete.
Mar 17, 2016 | Chevrolet Silverado 1500 Cars & Trucks
Key fob dont work, but door lock works ok, key fob battery change.
1. Get in your vehicle.
2. Close the door.
3. Put key in ignition
4. Do not turn on the ignition yet.
5. Hold down on the unlock button on the door panel. Do not let up.
6. Turn the key to ON, OFF, ON, OFF (while still holding the unlock button on the door panel).
7. Release the unlock button.
8. The door locks should cycle, indicating that you did everything correctly.
9. Have all your remote entry fobs available. Hold down on both the lock and unlock buttons until the door locks cycle. Do the same on all key fobs. This will re-program all of them.
10. Turn ON the ignition key to exit the program mode.
11. DONE.
Apr 18, 2014 | 1999 Chevrolet Silverado 1500
2001 Mercury Villager keyless remote is malfunctioning
Keyless Entry
The keyless entry system consists of the following:
  • smart entry control(SEC)/timer module
  • keyless entry remote transmitters
  • power door lock actuators
  • body side door power door lock actuator
  • liftgate actuator
  • power door lock switches
  • door ajar switches
  • Principles of Operation
    All doors can be locked at once by turning the door key lock switch to the locked position. An individual door can be unlocked by moving the door key lock switch to the unlocked position and turning it again within five seconds; all the doors (including the liftgate) will unlock.
    The smart lock system is designed to keep the driver from locking his keys in the car. It will lock and then unlock all the doors if the smart entry control(SEC)/timer module detects the following conditions:
    • The ignition key still in the ignition.
    • A front door is open.
    • A door lock switch has been pushed to the lock position.
    The panic feature has a duration of 30 seconds from the last time the PANIC button is pressed. When locking the doors from the remote transmitter, the horn chirp/lamp flash feature can be disabled or enabled by holding the LOCK and UNLOCK buttons for two seconds. The hazards will flash three times to confirm that the feature has be enabled or disabled.
The control module probably see's an input that shouldn't be there . lock Switch , door ajar etc... Don't think it has anything to do with the remote . Some part stores have a tester to see if signal from the remote is working . Or the dealer ! Take it an see if your remote is sending a signal without you pressing any buttons .
If it is you need a new one .
May 19, 2017 | Cars & Trucks
99 blazer keyless entry
I don't know if this is procedure you followed? There is door lock receiver under the dash. The receiver sends message to bcm the bcm controls the door lock/unlock relays accordingly. Any applicable trouble codes?
Mar 22, 2017 | 1999 Chevrolet Blazer
Battery died on my 1999 vw jetta fob key and now the fob will not lock or unlock the doors
once you have replaced the battery you must reset,unlock/hold key over 30 secs...then lock/hold key over 30 secs.....then press/hold unlock button on remote for 30 secs.....reset..
Oct 31, 2010 | Volkswagen Jetta Cars & Trucks
1999 porsche 996 replaced key fob battery disconnected battery now trunk releses are locked and cant access battery.How do you open frt trunk manually
Assuming the car battery is ok (if not, buy a male to male cigarette lighter at the auto store and connect to another car until charged enough to unlock the doors...but don't try to crank the ignition!). The trunks won't open if the battery went dead with the alarm set because arming the alarm physically locks the releases.
Sounds like the key code is switched off because you replaced the key fob battery. Try unlocking the car manual with the key in the door lock. Then switch the ignition on to reactive the keyless entry. If this does not work, you might also try pressing the fob unlock button with the key in the door lock until the dash led flashes.
Jun 10, 2010 | 1999 Porsche 911 Carrera
The keyles entry on my 2001 gmc van stoped unlocking the doors now it willnot lock or unlock them
the way to start is by checking all fues.Then make sure dooe locks work from car switch then we can check remotes.
Nov 09, 2009 | OEM Systems Vehicle Parts & Accessories
Program fob
Instructions to program a keyless entry remote for a Chevy Silverado. They also work on 2003, 2004 and 2006 Suburbans.
  1. Close all the vehicle doors.
  2. Insert the ignition key into the ignition lock cylinder.
  3. Press and hold the DOOR unlock switch.
  4. While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to four transmitters.
  8. Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
  9. Operate the transmitter functions in order to verify correct system operation
Apr 19, 2009 | 1999 Chevrolet Silverado 1500
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Car Audio & Video Logo
66 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
