You should be able to find the model number as it appears in several places but you might have to scrape some paint and rust off to find it. If that's what you really want and can't find the model number or manufacturer's plate, let me know and I'll try to give you the locations.
The only sure place to decode the serial number requires payment unfortunately. It's at http://www.forkliftyear.com/
Get the VIN number from your registration. Contact a dealer for your car model (Honda, Toyota) and ask them. They can tell you what engine it is. No mechanic would need the actual engine serial number.
In the Toyota Coaster 4x4 with the BB58 4.1-liter engine, the engine number is typically located on the engine block itself. The exact location can vary slightly depending on the model year and specific configuration, but it's commonly stamped onto a flat surface on the side or top of the engine block.
To find it, you may need to open the hood and visually inspect the engine block. Look around the sides and top for a series of alphanumeric characters stamped into the metal. The engine number is usually a combination of letters and numbers and may be preceded or followed by the term "Engine No." or "Eng No."
If you're having trouble locating it, consulting the vehicle's owner manual or contacting a Toyota dealership or service center for assistance could be helpful. They may be able to provide you with more precise instructions or even visual aids to help you locate the engine number.
12 is not a fault code it is the code that tells the user the computer is in read mode of computer diagnostic's. so if the only thing it flashes is 12 then you have no fault codes stored.
The engine model is on the emissions label under the hood on the hood. This the number you need to order parts etc... the actual serial no of the engine is usually not required only VIN and eng model.
