Question about Alesis RA-150 Amplifier
Distortion in one channel
The RH Channel distorts and the output stalls at 1watt onwards.
Help needed.
  • Anonymous Dec 07, 2007
    I have experienced continual distortion on rt. channel when volume is turned up to less than 1/3 vol. I have sent the amp into repair shop twice but they can find no problem. I have tried 3 different sets of speaker - same problem.
  • Anonymous Apr 20, 2008
    Replaced IC AN7062. with new one purchased from Vance Baldwin. Problem persists.
Hello I have a Alesis RA150 power amp my problem is only one side is working the other side i have no sound how can I fix that plz
Posted on Oct 09, 2008
  • 682 Answers
Your right output component (transistor or integrated circuit needs to be replaced)
Posted on Mar 11, 2008
Right channel distorted denon UDRA M7
Hello there, I have the same amplifier and now it has the same problem on the right output. Have you found out how to fix it? Thanks!
Nov 07, 2013 | Audio Players & Recorders
One channel distorted on my peavey 1200 watt amp
Sounds like your output stage took a dump!
Dec 18, 2012 | Car Audio & Video
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Jul 17, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Channel 2 Distorted/Clip light comes on
It sounds like the final amplification section is OK now. I'd be looking for a noisy transistor or transistor pair at the "front end" of the unit. There may also be a shorted coupling cap between the stages. If you can Email me the schematics, I can provide more details.
Dan
May 27, 2009 | Behringer EUROPOWER EP2500 Amplifier
Distortion on left channel of analog output
Based upon your description, the most likely caue is the D-A converter chip inside the marantz. This is a relatively common failure. Replacing the IC should resolve the problem.
Dan
May 20, 2009 | Marantz DV8300 DVD Player
Center channel speaker output problem
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Jan 07, 2009 | Audio Players & Recorders
Shorted a RH front speaker, now there is no output from RH channels at all
The output stage of the amplifier (RH channel) was probabla damaged from the grounded cable. The heat in the speaker means that the coil (d^speaker) is recieveng DC power from the damaged amplifier. Audio amplifiers are not special and can be fixed. In many cases, the output stage is a power MOSFET or a power audio amp IC. The only issue is the availability of the parts in your area.
Jun 14, 2007 | MTX RT404 Car Audio Amplifier
Alesis RA-150 Amplifier Logo
308 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
