N
NICOLA REID Posted on Oct 29, 2014
Just picked up a Pioneer ZRA 700 hifi system neither one of the duel cassette players works. If insert cassette tape in either deck, tape does not play but continuoisly goes back and forth for auto re
Just picked up a Pioneer ZRA 700 hifi system neither one of the duel cassette players works. If insert cassette tape in either deck, tape does not play but continuoisly goes back and forth for auto reverse without playing either side of tape . I've sent a message to the person I brought it from who says they checked it yesterday & it was ok. Any ideas please ?.
luke825
Level 1:
New Friend:
  • Contributor 41 Answers
  • Posted on Oct 30, 2014
luke825
Contributor
Level 1:
New Friend:
Answers
41
Questions
Helped
17736
Points
66
Make sure your tape spools turn freely, try a differnet tape. Could be a shared drive belt that has broken inside after long storage?
5 Related Answers
Anonymous
  • 1512 Answers
  • Posted on Jan 26, 2008
SOURCE: Remote control for Technics RS TR 272 Dual Cassette Deck
a system remote is the only option for you here. The deck does not have its own remote receiver. Sorry to break the bad news to you.
Anonymous
  • 579 Answers
  • Posted on Feb 10, 2008
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Anonymous
  • Posted on Jan 04, 2010
SOURCE: Dual Cassette Deck won't stop or auto-reverse
My Tascam 202 wr need to replace belts on recorder of duel deck? what is the best way
Anonymous
  • 8546 Answers
  • Posted on Mar 19, 2010
SOURCE: Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Testimonial: "This makes sense to me...thanks for taking the time to answer this."
petraman7
Scott Frye
  • 1175 Answers
  • Posted on Mar 25, 2010
SOURCE: tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Pioneer Hifi/cassette tape deck Amplifier DC-Z82. We tried to record a radio programme to tape and the tape wouldn't move.
Hello Anonymous, you can have dirty heads and guides, also the internal key Rec-Play could be wrong
You should do a full maintenance of the cassette system
Consult a specialized technical service
Greetings Franco Dosil
Hola Anonymous, puedes tener sucios los cabezales y las gu?as, tambi?n podr?a estar mal la llave interna Rec-Play
Deber?as hacerle un mantenimiento completo al sistema de cassette
Consulta un servicio t?cnico especializado
Saludos Franco Dosil
Hookup soney duel tape deck to onkyo equalizer
If you are trying to equalize the sound from one half to the other ... you cannot, unless there are separate INPUT and OUTPUT jacks on the back. Otherwise you will need a second cassette deck.
Where can I buy Pioneer CT-W701R Stereo Double Cassette Tape Deck Riemen Belt
If the methods listed in the manual won't open the door, then the tape is not inserted properly. Insert a golf tee in one of the two small holes below the tape door and slightly adjust the position of the tape up, down, or sideways. Then press the eject button and it should open. This will only work if the belt is OK.
Pioneer Cassette Deck Repair
Anything that eats tapes means the take-up torque is low of stopping due to bad belts or a bad Idler system or even cracked tires. The transport have to be taken out and those parts replaced and then it will work again.
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
3answers
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
2answers
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
 Grubhead
Grubhead
SmartAviator
SmartAviator
