Cars & Trucks Logo
paul klinger Posted on Oct 30, 2014
A little more info on the nitro bmwx 4738 car dvd player I need to know the pin outs for the plug that has the power and grnd mine is missing. The male reciever socket is rectangular with 8 pins on the top and 8 on the bottom thank you paul
5 Related Answers
Jessie Goss
  • 162 Answers
  • Posted on Aug 12, 2007
SOURCE: IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
A
Anonymous
  • Posted on Sep 29, 2008
SOURCE: RADIO INSTALLING
with the bose sound system you have to bypass the audio system through the factory amp. the factory is located behind the right side of the glove box.
Anonymous
  • 63 Answers
  • Posted on Jan 22, 2009
SOURCE: Case front firewire port to motherboard connection???
Yeh dont plug it into a USB header...
yes if you buy a PCI firewire card they will have 1 or 2 headers on the card so you can fit your front Firewire port to it...
[Belkin cards 99% of the time have headers on the card]
Let me know...
Matt
Anonymous
  • 4669 Answers
  • Posted on Mar 24, 2009
SOURCE: "No Connectin" at OBD II plug
Will it give you codes on the dash if you turn the key on and off 3 times.
proton77
Mandeep Singh
  • 1184 Answers
  • Posted on Apr 08, 2009
SOURCE: Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
2007 Dodge Nitro. What causes to say 'key in ignition' when there is no key in the ignition?
The first thing to do is check all the fuses, but it sounds like you need a mobile auto electrician.
Fuse Box Diagram Dodge Nitro (2007-2012)
https://fuse-box.info > dodge > dodge-nitro-2007-2012...
In this article, you will find fuse box diagrams of Dodge Nitro 2007, 2008, 2009, 2010, 2011 and 2012, get information about the location of the fuse panels ...
Does the 2011 Dodge Nitro have a fuse for the air compressor?
If you mean the Air Conditioning and its compressor, yes it does. Press CTRL+F and type 'air'.
Fuse Box Diagram Dodge Nitro (2007-2012) - Fuse-Box.info
2011, 2012 - The Integrated Power Module (IPM) is located in the engine compartment near the battery. This center contains cartridge fuses, mini ...
Firing order & Wire Routing for 2009 Dodge Nitro 3.7 w/ three coil setup
The firing order for v6 is 165432
The driver side cylinder bank is numbered from front to rear-- 2-4-6
The passenger side cylinder bank is numbered from front to rear 1-3-5
The picture is for your coil pack, hopefully. So you can see how the coil towers are numbered.
My database for 09 showed coil on plug ignition. Is this the original engine?
I did see info for 07--3.7L that did appear to show a coil pack in tune-up manual.
On my 07 doge nitro do you replace coil along when replacing plugs
Nacho, Coils are not normally replaced when changing spark plugs. Use the factory recommended plugs(OEM) . Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.nitroforumz.com/threads/changing-spark-plugs.30635
Changing Nitro Plugs 3 7 4 0L
how to change spark plugs in dodge nitro
More Information for NGK 6987
1helpful
I have a BMWx-309 Nitro Tweeters. Where do i wire? Front speakers on cd player,door speaker?
Assuming you do not have factory tweeters then either is acceptable. Use whichever is easier to get to...door speakers if mounting tweeters on door or cd player if mounting on dash.
2005 dodge nitro
Bo, Re POST year, make, model, and complete question so we, here at fixya can answer your question effectively.
2005 Dodge Nitro Details Specification
Newest Problem Reports for the Dodge Nitro
My Dodge Dodge Owners Service Manuals Dodge Cars Minivans SUVs
http://www.repairservicemanuals.com/Dodge
Looking for the plug in harness for a Nitro bmwx 33.2 where can I get 8th?
BMWx-33.2W :: 3.2" Widescreen Head Units, Digital TFT ...
www.nitroelectronics.com > Car Electronics > Car Video
HEAD UNITS Digital TFT One DIN Widescreen 3.2" BMWX-33.2 By Nitro. ... Camera Input (without camera); 4 Channel High Power Output; Plug-In Harness ...
One Din with Monitor - NITRO-AUDIO
www.nitro-audio.com/one-din-with-monitor.html
BMWX-3.2 3.2" Digital TFT One DIN Widescreen/Touch Screen ... Plug-In Harness • NTSC/PAL System Compatible ... BMWX-33.2W 3.2" Digital TFT One DIN ...
NITRO BMWX 5393BT Car Stereo Bench test - YouTube
? 1:36
https://www.youtube.com/watch?v=PHjoXd55mTo
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
2answers
I just got a 2003 town & country and the DVD player in it will not work and I can't figure out why....
You need to run a continuity test
on the DVD player first, to see if
it has any bad connections inside.
If that is okay then a bad fuse or
a problem in the wiring.
DOES mr935650 CAR rADIO/cD PLAYER HAVE AN INTERNAL FUSE?
I know its a little but I had same problem with mine power to unit but wont turn on.
I removed the stero removed the plug then hold down the button with return writte under it ( I think its number 3) then plug it back in. as far as the unlock code If the car is registared i8n your name ring Misibishi with thye VIN number they should be able to help you out.
Toyota power seats
the connectors should match up if not wouldnt use
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
