Re: Where is the fuse for the PTO on my Cub Cadet 1212?
If your engine cranks then fuse is okay. Your do have a relay, seat switch, reverse switch, PTO switch, and the ignition switch that in the circuit for the PTO. Here is the electrical diagram for your mower.
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Did you check for power at the pto switch? Start with checking that, then check the wire from the PTO switch to see if it has power all the way to the PTO clutch. If there is power to the clutch, and the belt is good and routed properly it's probably the PTO clutch.
IF connecting that one hot wire to the pto made it engage then you either have a broken/cut/bad connection/wire to the pto or the switch is bad.
What you did by using the hotwire to the pto is bypass all the wiring and the switch for the pto.
You can determine if it's the switch real quick if it only has two connections/wires to the switch. Pull the switch, remove the wires and touch them together, after you have the mower in the condition under which the pto would engage. If the pto engages it's the switch for sure.
Take all the proper safety precautions. Don't let the wires touch anything else.
first start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. if not use a twelve volt test light,hook aligator end to a good groundand the needle end,,,touch to the pto switchharness to see if you have power to the pto switch. if you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. you can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It willengage if it is good .using either wire is ok as all it will be doing is completing a circuit. hope this helps.
