Question about Dell Inspiron XPS M1710 Notebook
How to change light colors on outside of PC
Always comes back to red lights
  • JonSnell Electronic
    JonSnell Electronic Oct 29, 2014
    Hi John G, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
SOURCE:
graysand
  • 558 Answers
SOURCE: XPS 730 LED light issue...
you might want toreplace the theatre lighting card.
good kuck
Posted on Sep 22, 2009
What is wrong with my camera? The light turns on and nothing happens, then it goes out again?
Whether the lens is coming outside or not ? and what is the color of the blinking light ? if its red then Your camera could either have a lens error or other problem. YOu need enough battery source to run your digital camera. Change the battery on your coolpix and let me know.
Feb 16, 2015 | Nikon COOLPIX L810
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2013 | Home
Screen is in night mode how to get back to day mode
Your unit is probably set up to change to night colors when the lighting outside is low. It should go back to day colors when more light reaches the GPS.
If you still want to change it, tap on the screen, tap on the preferences icon, then tap on the right arrow until you see an icon laebled "USE DAY COLORS". Tap on it and you'll have your day colors back.
Apr 01, 2010 | Tomtom ONE GPS Receiver
good kuck
Sep 16, 2009 | Dell XPS 730X Desktop Computer
Check engine light went on
the check engine light is for the engine electronic controls, there is a fault, have the trouble codes tested by the dealer to see what is making the light come on. I assuming this light is yellow/amber colored? if not, and it is red it is a low oil pressure warning light, in that case the oil pressure sending unit on the engine may be defective.
May 13, 2009 | 1995 Honda Accord
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Why is the ''snowflake light'' showing up red in my car?
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
Nov 18, 2008 | 1999 Mercury Cougar
HELP! Can you help me Slinte?
Can you post the board location number of thr resistor that is circled in yellow such as R8006 and I will post the rating of that resistor as thats what the problem is usually one or two of the resistors will burn when the ICs go out.
May 10, 2008 | Hitachi 51SWX20B 51" Rear Projection...
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Dell Inspiron XPS M1710 Notebook Logo
Clive
Clive
Alun Cox
