Gail Downing Posted on Oct 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GET MY COMPUTER TO SHOW VIDEO
HOOKED INTO TV WILL NOT SHOW VIDEO OF NETFLIX ETC.
Harrie
Level 3:
Top Expert:
  • Master 6,746 Answers
  • Posted on Oct 30, 2014
 Harrie
Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1285680
Points
83153
If you did connect the computer to the tv with a HDMI cable, you have to look there. HDMI also protects giving through copy protected content. Please read everything about HDMI and digital rights.
How to get netflix on tv
Is your TV a smart TV, or do you have a computer or smart device connected to it (like an Amazon Fire Stick or Fire TV, an Apple TV, or a Roku)?
I have a new house next door to my previous one that I had Netflix. I hooked up to internet have cable etc but can't get Netflix on my tv please help!
hi Jonel.
see if this helps you out.
Method 2 Smart TV
  1. Determine if your TV is a Smart TV. Smart TVs connect to your home network, and can run media streaming apps such as Netflix. ...
  2. Connect your Smart TV to your home network. ...
  3. Open your Smart TV apps. ...
  4. Select the Netflix app. ...
  5. Log in with your Netflix account. ...
  6. Browse using your remote.
6 Simple Ways to Watch Netflix on TV - wikiHow
How do you set up Netflix on TV?
Connect your Internet-ready television either with an Ethernet cable or wirelessly to your router. Follow the steps on the television to connect it wirelessly. 2. Select theNetflix Apply from the menu on the television screen.
How to Set Up Netflix Streaming for a TV ' Chron.com
smallbusiness.chron.com/set-up-netflix-streaming-tv-27369.html Search for: How do you set up Netflix on TV?
if this does not help go to this link might help you.
how to get netflix on my tv Google Search
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
1helpful
Why is there no picture but sound?
Can you tell us a bit more about the problem? It would be helpful if we knew:
1) What device are you using to connect to Netflix (computer, DVD player, TV, etc.)?
2) When you use that device for something other than Netflix, do you see a picture? So if you're using a DVD player, can you play DVDs? Can you watch TV?
3) Can you log into your Netflix account on your computer and watch movies on your computer? Can you login from someone else's computer and try that?
3) When did the problem start?
Some shot-in-the-dark steps that apply to all electronics:
1) Turn everything off. Turn it all back on.
2) If that doesn't work, unplug everything. Wait 30 seconds, then plug it all back in.
3) Check all the cables (from power to your TV and Netflix device, cables coming from your peripherals to the TV, etc.). Even if they seem to be well-seated, unplug them and plug them back in.
4) Try new connections. If your TV was connected by HDMI, and you have a different way of connecting your device (DVI, component, RCA, s-video, coax, whatever) try it. If your device connects to the Internet wirelessly, see if you can get a wired connection. Swap cables wherever you can.
5) If you can, try interchanging components. So, for example, try connecting to a different HDMI port on your TV. Try other devices on your TV. Take your Netflix device (if it's not your TV) to a different TV.
Those last 2 steps may solve the problem, but are more likely to isolate the problem. (For example, if your DVD player doesn't work no matter what TV it's connected to, then the problem is the DVD player.)
Update us with as much info as you can.
Mar 29, 2015 • Netflix
Netflix customer login
if you're streaming the video from a computer to a tv then you need the audio source hooked up to the TV not the computer. If it is a TV or player with the Netflix APP then you'll need to upgrade your network bandwidth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
2answers
How to record from netflix to chromebook c7
netflix streams are DRM protected so don't get your hopes up ripping the video with a simple piece of software.
I want to watch netflix on my proscan tv, but I've put the tv on every channel and netflix doesn't pop up
it could be that your scrolling the channels and ports for your dish network menu and not your tv menu if your using a remote try changing the setting via the tv itself, also try disconnecting the dish network supply then try try using the net gear stuff, personally I would say get the new x-box one system because it has blue-ray capabilities, stream music and videos, movies, it has Netflix and hulu and all that stuff that your computer and phones can do now including video chat, voice recognition, hands free movements recognition and yeah it just does everything... hope this helps
No red and no sound. Happened suddenly today Feb 16
Does tv show No Red in all inputs like tv programs, dvd player etc?
Let me know connection setup with tv and what is video source hooked in tv to diagnose problem.
Unplug tv and video source (cable box, dvd player etc) from wall socket for minute to get them reset, replug back in and turn both units On and check.
Thanks.
 Grubhead
Grubhead
SmartAviator
SmartAviator
