Panasonic NV-FJ620 VHS/S-VHS playback VCR Logo
A
Alan Trickett Posted on Oct 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the remote the date etc. programmed OK but how do I set up the actual recorder with undefined
This is for my aged parents who have VHS tapes of family growing up, parties etc
Grubhead
Level 3:
  • Panasonic Master 5,755 Answers
  • Posted on Nov 05, 2014
 Grubhead
Panasonic Master
Level 3:
Answers
5755
Questions
Helped
1662653
Points
11417
Panasonic are very good at having free PDF copies of user manuals. However if you just want to playback old tapes then all you need do is connect the vcr to a TV and press play. You might need to adjust the tracking using the controls on the remote. But the picture should play. If you see snow on the screen, but can hear sound, then the tape heads will need to be cleaned. You can get a VCR cleaning tape for that.
5 Related Answers
Michael Borelli
  • 979 Answers
  • Posted on Mar 21, 2008
SOURCE: lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Anonymous
  • Posted on Apr 05, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Anonymous
  • 9 Answers
  • Posted on Jan 03, 2009
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Anonymous
  • 51 Answers
  • Posted on Jan 04, 2009
SOURCE: Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
Kevin LaPointe
  • Posted on Jan 16, 2009
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Unlocking the actual (safe)dvd/vhs button (as i don’t have remote) on front of LG9120W machine ...?? pls Help ??????
f the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
2answers
Dual Deck VHS Cassette Recorder
rca service in Dallas..one moment please
First. Don't have the remote. On a magnavox dv220mw9 model. Plays regular. VHS tapes ok it won't play a recorded tape on our 32 inch Curtis flat screen tv. Where can I get a remote for this. Also wi
You can get a general purpose "universal remote" and program it but difficult and tough to get all of the functions to work. I would recommend stepping up the price paid for a remote to around 100 - 120 dollars. The one I recommend is the URC remote. This one can be programmed with multiple components to a single button. There are many out there other than URC but it is one the I use and have found to be very reliable.
2answers
How to set parental block on tv so it cant even be turned on Tv is a proscan 47lb45h
DTV parental controls include blocking of unrated programming, channel-by-channel blocking and blocking by content rating levels. You have control over what information gets displayed on the Electronic Program Guide, and can unlock controls for a particular time frame.
Initially your service uses default settings, which allow access to all programs. Ratings are set from the Main Account. Subaccounts (individual user accounts) can be set up for household members (toddlers, tweens and teens), based on their viewing needs. Once Parental Controls are activated, an icon will appear in the navigation menu.
Parental Control Settings from the Main Account
Press the Menu key on your remote control and arrow to the Settings tab. Press OK on your remote. Enter your Password, arrow to OK and press OK. Arrow to the Parental Control section and highlight Change, press OK. This takes you to the Users tab. Here ratings for Movies, TV and Content are set up along with Unlock Timeout. Each rating has a drop-down menu for age appropriate programming. The Content ratings work in addition to the Movie and TV ratings and let you block unwanted content such as *** or violence.
Tip: The Unlock Timeout lets you deactivate the Parental Controls for 30 minutes to 3 hours and after that time will automatically reactivate parental controls.
To choose your Movie settings, press OK and a drop-down menu will appear. Select the desired rating and press OK. Next you can do the same for TV Ratings, and Unlock Timeout. Arrow to Content Rating. Select the ratings you want to block, press OK and a checkmark will appear. To remove the content rating press OK again. Ensure that the Enable Parental Control box is checked. If it is not checked, Parental Control is not enabled. Arrow to Done and press OK, which takes you back to the Preferences tab. Arrow down to OK and press OK. You will be returned to your program.
NOTE: Any Parental Controls set will only take effect if you check the Enable Parental Controls option on the Main Account and exit the Preferences tab via the OK button. Otherwise, the default setting is in effect, allowing the viewing of all programs regardless of settings for individual user accounts.
How to set up Subaccounts (Individual User Accounts)
Press the Menu key on your remote control and arrow to the Settings tab. Press the Select key on your remote. Input your Password, arrow to OK and press the Select key on your remote. If the electronic keyboard appears, just press the Select key on your remote again. Arrow to the Users tab and press Select. Arrow to Add, press Select. Arrow to New Login and press Select to display a digital keyboard. Use your remote's Arrow keys and the Select key to enter a Login Name. When done, arrow to Enter on the digital keyboard and press Select. The new Login Name will appear in the box.
Arrow to and choose the desired Movie Rating for this User and press Select. Now, arrow to and choose the desired TV Rating and press Select. Arrow to and enter New Password, Select. Arrow to Confirm Password and reenter what you typed in the New Password field, Select. Arrow to Allowance. If you would like to set a spending limit for Pay Per View events and movies, enter the amount and press Select. Arrow down to Submit and press Select. To restore TV viewing, press the Menu button on the remote twice.
TVY
All Children
This program is designed to be appropriate for all children. Whether animated or live-action, the themes and elements in this program are specifically designed for a very young audience, including children from ages 2-6. This program is not expected to frighten younger children.
TVY7
Directed to Older Children
This program is designed for children age 7 and above. It may be more appropriate for children who have acquired the developmental skills needed to distinguish between make-believe and reality. Themes and elements in this program may include mild fantasy violence or comedic violence, or may frighten children under the age of 7. Therefore, parents may wish to consider the suitability of this program for their very young children.
TVY7FV
Directed to Older Children - Fantasy Violence
For those programs where fantasy violence may be more intense or more combative than other programs in this category, such programs will be designated TV-Y7-FV.
TVG
General Audience
Most parents would find this program suitable for all ages. Although this rating does not signify a program designed specifically for children, most parents may let younger children watch this program unattended. It contains little or no violence, no strong language and little or no sexual dialogue or situations.
TVPG
Parental Guidance Suggested
This program contains material that parents may find unsuitable for younger children. Many parents may want to watch it with their younger children. The theme itself may call for parental guidance and/or the program may contain one or more of the following: some suggestive dialogue (D), infrequent coarse language (L), some sexual situations (S), or moderate violence (V).
TV14
Parents Strongly Cautioned
This program contains some material that many parents would find unsuitable for children under 14 years of age. Parents are strongly urged to exercise greater care in monitoring this program and are cautioned against letting children under the age of 14 watch unattended. This program may contain one or more of the following: intensely suggestive dialogue (D), strong coarse language (L), intense sexual situations (S), or intense violence (V).
TVMA
Mature Audience Only
This program is specifically designed to be viewed by adults and therefore may be unsuitable for children under 17. This program may contain one or more of the following: crude indecent language (L), explicit sexual activity (S), or graphic violence (V).
G
General Audiences
The motion picture contains nothing that would offend parents for viewing by their children.
PG
Parents are urged to use "parental guidance", as the motion picture may contain some material parents might not like for their younger children to view.
PG-13
Parents are urged to be cautious. Some material may be inappropriate for pre-teenagers.
R
Restricted
Contains some adult material. Parents are urged to learn more about the motion picture before taking their younger children with them. Generally, it is not appropriate for parents to bring their young children with them to r-rated motion pictures.
NC-17
No One 17 And Under Admitted
Patently adult. Children are not admitted.
Hope it helped.
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
1helpful
Time
Most VCRs of the last 10+ years are programmed via the remote box. If you have the matching remote, there should be a button which brings up an on-screen menu where you can select various functions such as setting the time/date, tape speed, channel programming, and the unattended recording you desire. Take a look here for an online manual: http://www.emersonaudiovideo.com/pdf/om/EWV603.pdf
2helpful
How to set clock on Orion VCR VR0419
Most late VCRs require the remote box to set the clock, timed recording etc. Assuming you have the Orion remote, it should have a programming or menu button, and the function you need can be selected from a list of options. If the remote is an aftermarket unit (non-Orion), it must have the capability to do the advanced setup (clock set etc.). Many aftermarket remotes only do basic channel selection, and tape functions (play, rewind, stop, etc.).
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
