Tablets & eReaders Logo
Kimberly Spangler Posted on Oct 29, 2014
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO COMMAND. So, can someone help me????????
Manuel Zarsadias
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 70 Answers
  • Posted on Oct 29, 2014
Manuel Zarsadias
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
70
Questions
0
Helped
12522
Points
89
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
4 Related Answers
Anonymous
  • Posted on Dec 28, 2011
SOURCE: The tablet turns on but seems frozen and shows the android screen and nothing else. Tried to reset it but it does the same thing
so wat do i do
Anonymous
  • Posted on Jan 18, 2012
SOURCE: I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HA
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
Anonymous
  • 4961 Answers
  • Posted on Aug 21, 2012
SOURCE: i need to reboot my mid android 2.2
push on power + home button on the other side and until it reboots the device.
Jim Dowell
  • 345 Answers
  • Posted on Dec 20, 2012
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Maylong M-270 Mobility Internet Tablet. I have a mobility 7 tablet M 270 that shows the Android laying down, why please?
My guess is that it needs charging, or there is an issue with the Android Operating System.
The first thing to do is power it down for 5 minutes and then plug the charging lead into it.
What does a bright orange triangle( with a ! in the middle of it),mean when tablet will not on ?
Thread: Android bot laying down with exclamation mark - Asus ...
www.transformerforums.com > ... > Asus Transformer (TF101) Help
Apr 7, 2012 - 10 posts - ‎5 authors
Hello: With the tablet powered off I press down "- volume button" and ... Guys - you can only do a cold boot or factory reset through the .... No worries I've sounded grumpy occasionally myself - even big, bright, yellow, grinning me ... dead android with redtriangle ... what does an android avatar laid out mean.
Warning triangle and thermometer on charge s... ' Samsung Galaxy S ...
forum.xda-developers.com/.../warning-triangle-thermometer-charge-t15...
Apr 13, 2012 - 5 posts - ‎4 authors
I also can't turn the phone on unless I go to Recovery and reboot the system that way.Does anyone know what this means? Thanks.
How to factory reset a hkc tablet model number a072d
Try this
1.hold down the power key for 10 seconds to turn off the unit with nothing hooked to the unit (no ac/no usb/nothing)
2. hold the volume up key (+) and the power, once the screen starts to turn on release the keys.
3. NEXT you should get a robot laying down with a red triangle, push the power key one time. This will get you to the menu screen.
4. from here you chose the reset factory by using the volume down (-). Once you have that line highlighted press the power button.
5. next use the (-) key to get to yes to reset/reboot followed by the power key to chose the option.
6. tablet will come back on and be just like you got it from the store originally.
I have a klu by Curtis LT -1041-c screen went black can't get it to come back on.help tablet.
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and 'Power' key
3. When "Klu by Curtis" splash screen shows release the power key
4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the 'Volume Down' and 'Volume Up' and press the 'Power' keys to dislplay the BIOS screen.
6. Use the 'Volume Up/Down' keys to navigate choices (wipe data/factory reset) and the 'Power' key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select 'reboot system now' to restart tablet.
Done!
Acer iconia a700 tablet
Hi there if you follow this link http://www.acertabletforum.com/forum/rescue-squad-guides/5168-how-perform-factory-reset.html It will walk you through the reset process :)
2answers
My tablet comes on but has a green monster with a red triangle and it wont let my tablet get pass it
Hi.
There is corrupt data on the Proscan 7.
First of all if you have an SD card in the slot remove it and turn the Android on to see if it boots. If i does then you didn't have it inserted properly or its corrupt.
If is still shows a Android laying down then follow the procedure below.
1. IF YOUR TABLET IS ON, POWER IT OFF. 2. PRESS AND HOLD POWER UNTIL THE DEVICE POWERS ON, THEN IMMEDIATELY PRESS AND HOLD VOLUME DOWN (WHILE STILL PRESSING POWER). YOU WILL SEE THE WORD START WITH AN ARROW DRAWN AROUND IT.
3. PRESS VOLUME DOWN TWICE TO DESIGNATE RECOVERY MODE.
4. PRESS POWER TO RESTART INTO RECOVERY MODE. YOU WILL SEE AN IMAGE OF AN ANDROID ROBOT WITH A RED EXCLAMATION MARK.
5. WHILE HOLDING DOWN POWER, PRESS VOLUME UP.
6. USE THE VOLUME KEYS TO SCROLL TO "WIPE DATA/FACTORY RESET" AND PRESS POWER TO SELECT IT. 7. SCROLL DOWN TO "YES - ERASE ALL USER DATA" AND PRESS POWER TO SELECT IT.
Regards.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
