Question about Agfa SnapScan E25 Flatbed Scanner
Benq scanner 5250c driver for vista
My scanner driver will not work on vista
Re: benq scanner 5250c driver for vista
Hi alls, this is my solution for Benq Scanner 5250C under Win Vista and Win 7 [both 64bits and Ultimate version]; [sorry for my English Im Spanish]
- Disable signature verification of drivers;
* Start Menu à Run and type this command; bcdedit /set nointegritychecks ON
- Restart the computer.
- Install this driver from Benq homepage; []
Support page;
Driver to download;
Install it with Administrator privilege [right mouse button …] press yes when ask if you want install unsigned driver.
Run Mirascan driver, it say that not found any scanner, close this application, unplug the USB scanner and plug again the USB cord. Run again Mirascan … and calibration will start and all possibilities are ok.
Remember to enable the signature verification of drivers;
- Run; bcdedit /set nointegritychecks OFF
- Restart the PC.
by JoinMA
Posted on Oct 14, 2009
Re: benq scanner 5250c driver for vista - Agfa SnapScan E25 Flatbed Scanner Scanners
My scanner driver doesn't work on vista
Posted on Feb 21, 2008
Use "Vuescan" a beautiful software supporting over 700 models of scanners including this one under Vista.
Posted on Feb 16, 2008
VUESCAN DOES NOT WORK with Benq 5250C. As soon as it opens it crashes. I have no idea how to solve this one. Emailed Benq, they answered that since they do not sell this product anymore, they WILL NOT issue any driver for it usable on Vista. Does this mean one can throy the machine away now? That would be a shame...
Posted on Apr 19, 2009
SOURCE: benq flatbed scanner error ffff;0024 will not operate or scan
Let me tell you my experience. I've read in one of these many contributions that a person, after many attempts, changed the converter and... IT WORKED. I did the same, as a final attempt, and it worked. Now then, I used a multiple voltage converter with both polarities. I switched it to 12 V, positive in the centre. One more thing: trying to recover my universal AD/DC adaptor, I bought a 12 V, 1 A converter and IT DIDN'T WORK. So be patient
Best regards Carlos
Posted on Apr 11, 2008
0 characters
3 Points
I need the scanner BENQ 5000U drivers FOR WINDOWS VISTA
You can find yourself the Vista compatible drivers by going to below mentioned link:
Please let me know if the above solution helped.
Mar 03, 2010 | BenQ 5000U Scan to Web Scanner
Any compatible software for vista 64-bits? or any solution??
Go to control panel.
Open up device manager.
Find the benQ drivers that exist. If there is a yellow triangle by them with an exclamation point, it means that the software is not working.
Uninstall the drivers, regardless of whether they are damaged or not.
Go to the action menu, and click on "scan for hardware changes"
If driver software exists, vista should be able to find it and install automatically.
If the benQ 4300 scanner is a really old model, it may not work.
Jun 22, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Vista problem
You should be able to locate your driver here:
Thank you for using Fix Ya!
Aug 20, 2008 | BenQ S2W 5300U Color Scanner
Vista Driver : Benq 4300 scanner
I have a BenQ scanner and I've lost the driver. I use a vista laptop. Pls help with the software or do I throw the scanner away and look for other product?
Apr 01, 2008 | BenQ Scan to Web 4300U Flatbed Scanner
Benq flatbed scanner error ffff;0024 will not operate or scan
This appears to be a software or communication between scanner and computer.
go for the usual re-installation of the software program being used, i.e paperport or similar.
try removing and reinstalling the scanner itself.
unplug the unit for between 30-60 minutes, to eliminate power pack overheating issues.
unplug the comms cable ( USB or other ) and re-connect.
Mike @ Compurepair.
Feb 19, 2008 | Scanners
Scanner benq 5000u no work with wondow vista ultimate edition Go to that web page above and download those drivers and install then your scanner should work.. You need to install a compatibl;e Vista driver
Jul 01, 2007 | BenQ 5000U Scan to Web Scanner
Agfa SnapScan E25 Flatbed Scanner Logo
4,077 people viewed this question
Top Agfa Scanners Experts
Starnley Johnwells
Starnley Johnwells
Are you an Agfa Scanner Expert? Answer questions, earn points and help others
