Question about HP Officejet 5510 All-In-One Thermal Printer
Number of copies stuck on "9"
The automatic setting for "number of copies" is stuck on 9. I can reset that number manually .. and I have to remember to reset it every time I print. Otherwise I get 9 copies. I have looked for some place in the HP software to change the automatic setting, but can't find one. P.S. My computer is an Intel Mac
    Genius:
  • 3,587 Answers
Not good. sounds like the printer memory got blasted, and stuck on number 9(remember the old Beatles White Album with that)?..at any rate, you may need to reset bios on pc and printer. had some power glitches lately, by chance?
Posted on Feb 06, 2008
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
Jun 11, 2015 | Uniden CEZ260 Corded Phone
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
How do I set the timer for a GE relocatable power tap EMP700UL-PC?
1) Copy following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
2) Timer turns ON automatically at dusk.
Push button to select duration of ON time.
d is probably dawn, so dawn-dusk
Maybe A is always ON, and maybe F always OFF.
1-9 will be number of hours timer remains ON, for example ON at dusk and OFF 9 hours later.
Dec 02, 2012 | GE Home
My watch is a casio wave ceptor 4774 wva 108hu and did not automatically reset to summertime
Hi,you need to look at the user manual..
just in case ,if you need to download a soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Mar 28, 2011 | Casio Wave Ceptor WVA104HLA8V Wrist Watch
When dialing number it is giving a "wrong number" signal
As you said, the set up is either trying to dial a "9" or other number to access an outside line before dialing your destination number. You will need to get into the menu and delete that command. After that, you should be able to dial out.
Remember to have the fax set to "FAX" not "TELEPHONE" to send and receive automatically.
May 18, 2010 | Brother FAX-1020e Plain Paper Thermal...
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
Copier will not operate
May want to check that default setting have been set for number and black and white, utilty then default settings reset to factory
Jun 22, 2009 | Minolta CF2001 Copier
Kx-tg5632 how do i forward call to my cell
you need to call your carrier and get a forwarding code and then a cancell code.
good luck
s
Jun 11, 2009 | Panasonic KX-T7630 Corded Phone
Printing too many pages
try this touch add functions key then printer settings one option should be number of copies make sure it is set at 1
Jan 21, 2009 | Canon imageRUNNER 5000 Copier
How can i download users' manual. I need to get the automatic "9" out of the outgoing fax number.
Inserting a dial prefix A dial prefix is a number or group of numbers that are automatically added to the beginning of every fax number you enter at the control panel or from the software. The maximum number of characters for a dial prefix is 50.
The default setting is Off . You might want to turn this setting on and enter a prefix if, for example, you have to dial a number such as 9 to get a telephone line outside of your company telephone system. While this setting is activated, you can dial a fax number without the dial prefix by using manual dial. For instructions, see Using manual dial .
To set the dial prefix
  1. On the all-in-one control panel, press Menu .
  2. Use the < or the > button to select Fax setup , and then press c00597634.gif .
  3. Press the > button once to select Fax Send setup , and then press c00597634.gif .
  4. Use the < or the > button to select Dial Prefix , and then press c00597634.gif .
  5. Use the < or the > button to select On or Off , and then press c00597634.gif .
  6. If you selected On , use the alphanumeric buttons to enter the prefix, and then press c00597634.gif . You can use numbers, pauses, and dialing symbols.
To get the manuals visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=18972&prodSeriesId=1140783
Regards,
Nikhil Gedam
Dec 16, 2008 | HP LaserJet 3050 All-In-One Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
203 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
