Sony VPL-ES3 Multimedia Projector Logo
M
Mohammad Moosa Posted on Oct 28, 2014
<!-- from fixya rte -->How to solve lamp cover error - Sony VPL-ES3 Multimedia Projector
Mitzibishi wd73c9 is turning itself off after a few seconds
The set may use the older self check or not:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Also take a look at another problem similar to yours I solved--this also might be helpful:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
1helpful
2answers
Sir, my canon ir 400 machine shows an error code 803. how can i solve the my problem. give detailed information to my mail. thanking u.
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
2helpful
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
1helpful
2answers
Sony wega 50" wont turn on and no sound it goes to standby
   According to the symptom self diagnostic system recomandation is :
   Lamp cover            error 3 times
- Lamp cover is not fastened securely.
Therefore please check the area of fault mension above, this will solve your problem.
Thanks for using fixya.
Replaced lamp in my sony55 inch tv still have lamp error 1
hello, if your still getting the lamp error then your lamp cover is'nt on right i'ld suggest taking cover off then re-installing it if the t.v. is'nt reading the lamp cover then it'll give you this error after re-placing the lamp, also take the lamp out and re-connect make sure the 2 prongs are on the lamp tight.
1helpful
Canon np1530 copier e220 error message problem, how can solve this problem?
E220 is a scanner error. means:
the exposure lamp is burnt.
try copying with the top cover open, if the lamp does npt work, exchange it.
Good Luck.
6helpful
2answers
E000225 & e000019 error code
The error code E0019 is the waste toner bottle is full you need to empity out the waste toner bottle and make sure the neck of the bottle is totaly clean and clear, a sensor reads dirt on the neck that the bottle is full. To clear that code after cleaning the waste toner, turn the main power switch off on the right side of the copier. The waste toner bottle is on the left hand side toward the rear of the copier and is held in with one screw. The E00225 deals with the scanning lamp. you will have to replace the lamp and the lamp PCB as a set to solve that problem. Good Luck...
3answers
Please help me solve this problem
problem with fuser, change thermistor or thermofuse, possibly lamp also
1helpful
Hi Marsat!
Actually both the filter cover and lamp covers have a long straight plastic part which is inserted in small hole. At the end of the holes are micro switches. When you fit the filter cover this switch is pressed and projector knows that it is ok to turn on. Similarly if lamp cover is loose the micro switch is not fully pressed resulting in this message. Tightening it presses the micro swith and the indication vanishes. In your case if plastic parts are intact, lamp cover screw is fully tight, filter is clean and properly seated with a click sound, then may be some micro switch has malfunctioned and you have no option but to take the projector to some qualified repariman.
Regards
Raheel
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
