Sewing Machines Logo
S
Susan Brebner Posted on Oct 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fill a bobbin for a model 100 Serial #53009473 SA-LR 29684
tom walsh
Level 2:
Sergeant:
  • Expert 228 Answers
  • Posted on Oct 28, 2014
tom walsh
Expert
Level 2:
Sergeant:
Answers
228
Questions
0
Helped
102207
Points
559
Most put the bobbin up top on a post, run the thread from the spool to the bobbin, and then rotate the bobbin by pressing it against a rubber covered wheel while running the sewing machine in normal 'forward' direction.
How to fix bobbin winding from skipping on Shark Euro Pro X model 7133 sewing machine
You may have already done these steps but when my bobbin stops/starts while filling it I do these steps.
1. Check the thread path to the bobbin area for your machine.
2. Make sure the bobbin is all the way down on the winding spindle.
3. Make sure the bobbin is pushed all the way to the right.
4. Check to make sure the bobbin edges aren't dragging on the guide. I've had this happen and the bobbin will "slip".
If the bobbin is almost full the guide will push it away to keep from over-filling it.
You should be able to control the speed of the bobbin fill the same as you do the sewing feed. Going too fast may also cause the bobbin fill to skip.
Good Sewing!
2answers
Might you be able to direct me to someone who could assist finding Antique machine needles?
I found needles for my antique Wilcox and Gibbs treadle from treadlelady on etsy.
How to thread the bobbin
Remove the Bobbin carrier. Place the bobbin in the carrier so the thread dispenses in a counterclockwise direction. Pull about 8" of thread free. Now, pull the thread through the metal brackets (tension) and place the assembly back in the sewing machine. Before you put it back, now is a good time to put a drop of oil on the race track.
1helpful
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
I have a singer touch tronic sewing machine. I need to fill the bobbin and I cannot get it to work. where can I buy more bobbins that have already been filled to fit my machine
Has the bobbin winder worked in the past and now faulting. Or are you unsure on how to use it?
There is a manual for a Touchtronic 2000 here http://www.singerco.com/uploads/download/432_touchtronic.pdf there may be more than one model Touch Tronic so plse check the serial number plate on the side of your machine to establish the actual model number, usually near the power inlet plug. then search for the appropriate manual at http://www.singerco.com/accessories/instruction-manuals. This excerpt shows that you wind the bobbin insitu in the bobbin case.
I'm not a fan of prewound bobbins, far better to deal with the bobbin winder issue. Winding your own thread means you can get far better colour matching to the fabric, and ensure you've got quality thread on the machine, and same thread top and bottom. (I prefer a quality cotton wrapped polyester or a polyester thread, Guttermann, Molynecke or Sylko Supreme). All of these factors affect stitching quality and the finished appearance of a seam.
Did you know that you can buy a freestanding unit to wind bobbins? Link to this item is here. http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx You may well find that this is the better solution to winding bobbins for this machine as winding them inside the bobbin housing doesn't give you a lot of control over the way the thread feeds onto the bobbin.
I can't lift the bobbin from the spindle after filling the bobbin. Sometimes it works and once in a while it will not move. No thread is underneath the bobbin. How do I get it off? Singer Sewing machine...
Sometimes the little spring on the spindle sticks out a bit too far and holds the bobbin on, the only way to get the bobbin off is to force it.
3helpful
4answers
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
