Question about Belkin (F5D7231-4) Wireless Router
Still trying! I still cant get wire free with my Belkin, I have inserted the cd that comes with it, and all i can get off it is the manual and i want the Set up Wizard why cant i get it? help1 please its driving me nuts.
  • 4 Answers
Re: Still trying!
To run the setup wizard manually, click Start, then Run.  Click the browse button and select your CD drive. Look for EasyInstall.exe and double click on it, then click OK to run.
Posted on Nov 11, 2007
0 characters
3 Points
Can not connect to internet on my laptop with belkin router f7d3302vi
The Setup CD does not automatically start.
  • If Belkin Setup does not run when you insert the CD-ROM, your computer may not be configured to open CDs automatically.
  • If Belkin Setup does not appear within 15 seconds, browse to your CD-ROM drive and open the "Belkin Setup" icon.
  • Alternatively, you may visit HYPERLINK "http://router/" or "" and perform the setup manually. Belkin Setup cannot find my Router.
If Belkin Setup is not able to communicate with your router during the installation process, please check the following items.
  • Make sure that the wireless hardware on your computer is turned on, if available.
  • Try connecting your computer to one of the four "wired" ports on the Router with an Ethernet cable.
  • Ensure that the Router is on. The front panel LED should be lit.
  • Unplug the Router's power supply for 10 seconds, then plug it back in. There may be firewall software on your computer preventing an outgoing connection. You may choose to temporarily disable this software before attempting setup.
once you login to router page by
under wireless click channel & ssid ->change a diffent name in ssid
under wireless click- >security ->use 64 bit wep and disablw wifi protected set uo would work fine
Aug 11, 2010 | Belkin (F5D5231-4) Router
Cant gain access to change settings on my router Belkin N1+
hardwire any computer to one of the wired ports in the router...
type in any web browser and log in to router setup utility manually....
password....leave it blank and click submit..
now you can configure settings manually....
Apr 20, 2010 | Belkin N1 Vision Wireless Router
Need to Download Belkin Setup Assistant
I would suggest the following:
in another computer attempt tocreate an image file of your driver cd as you mentioned you still haveit (I strongly suggest you don't lose it), then with a usb thumb drivemove that image into the computer where you want to run the wizard (the one that does not have the cd drive working). now for you to create an image iso file on the othercomputer (virtual image of your cd) you need nero or magiciso oranother program to create iso files from a cd, now to read that imageon your cd-trayless computer you can use a program called magic disc.
there are other programs you can use to make iso image files that are free
free alternatives to nero
magic disc
- this is free and it will create a virtual cd drive on your computerwithout cd drive, you just need to mount the iso file you created withthe other programs and it will work like a cd drive so you caninstallation cd without ever inserting the actual cd.
good luck!
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
My cd drive is brocken so i cant use insallation
Go to Belkin,com, click on support, click on routers. Now enter your model & info they request. You can download firmware,drivers & manuals. Also they have instructions on how to set up your router.
hope this helps.
Oct 18, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g router
It doesn't require Mac installer...Please check you have installation cd with you if not... Contact belkin tech support (toll free number) ...They will help you to configure manually...
Feb 18, 2009 | Belkin (F5D72304F5D7000) Router
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Installation cd
Dear Stuartmcrae,
Download the software for your N1 Vision Router ,from this URL:
Feb 29, 2008 | Belkin N1 Vision Router
Belkin (F5D7231-4) Wireless Router Logo
124 people viewed this question
Top Belkin Routers Experts
 C. Dante
C. Dante
steve morris
steve morris
Are you a Belkin Router Expert? Answer questions, earn points and help others
