Question about Paradyne COMSPHERE 3910 Modem
Alarm the alarm led stand on when i turn on the modem
0 characters
1 Points
My modem is not working Power Led will be displed but not diplayed ADSL led, PPOE lead or LAN conection led. all are atteched with modem but
maybe there is no internet connection coming on your modem...ask your internet provider if your connection is disconnected..if its not..maybe your modem is not working properly..replacing it will help..
Feb 20, 2011 | D-Link Modems
My Motorola sb5101 won't come online how do I troubleshoot this? My cable connection is fine. When the modem boots up the green power light comes on and stays on followed by the receive light and the send...
These modems are very tricky. When this type modem goes into stand by modem that indicates that you do have a connection to your internet service provider. The reason you cant get online is because all internet access is disabled wile the modem is in standby. If you look closely there is a button located on the top of the modem. This is the stand by button. If you hit that button it should take the modem out of stand by mode and reestablish your connection to the internet.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 02, 2010 | Arris SURFboard SB5101 Cable Modem
I move into a house that had a alam system by att
I assume that you do not have an alarm code to turn the system off.Contact the Professor and he can walk you through a defaulting of the alarmpanel.
Apr 21, 2010 | Ademco CIA Modem
Internet connection with arris modem does not go any farther than local
Check if:
  • the power cable is plugged in firmly in both ends?
  • reset the cable modem (use the reset button at the back of the modem)
If all led's stay off, and you are 100% sure that there is electricity on the powersocket, then there must be a technical problem. Contact UPC
Switch off the stand-by button, and you will be online again .
If the power-led is on and the online-led is blinking, then the stand-by button is active.
If the cable-led is continuosly on, then there is no data to/from the cable interface. Control if the cable is firmly connected
Reset the cable modem
If, after reset, there is still no data transfer, contact UPC.
If the Ethernet-led is off , then the ethernet link is disconnected.
Check if the PC or hub is firmly connected and/or powered
Ethernet link connected, but no traffic. Check if there is no problem with the hub, or check if there is no firewall blocking the traffic. Check also the tcp/ip settings
Nov 19, 2009 | Arris Modems
My modem keeps resetting at random times... The power stays on, since the orange PC-Activity LED stays on, but the other four LEDS (Power, Receive, Send, and Online) turn off and the modem reconnects to...
This is a firmware problem and the only way to resolve it is to do a firmware update on that device and you can get the firmware from the device manufacturer so you can load it to that modem...
Aug 08, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My 4100b is flashing ethernet green and power green that's all.
Hello I have the same modem and it had the same problem where it only lit the Power and the Ethernet LEDS. It is Quite easy to fix. All you have to do is Hard Reset it because soft resetting it wont do.
To hard reset it: 1. Hold the Reset button on the back of the modem for ~10 sec. until it resets itself. 2. >>Before all the LEDS disappear and only show power then Ethernet<< turn it off and unplug all the connections. Leave it unplugged for a few hours just to make sure that it goes back to Factory Default setting.
After that, plug everything in and turn it on.
Now, if it does not change and returns to normal. Press the Reset button while all the LEDS are lit then quickly unplug the 12vdc plug and wait.
If this fails, Search google for forums that mentions this similar modem ad same symptoms and see if they have a solution.
Hope it works, GOOD LUCK!!
Jul 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
NOkia seimens hardware problem
1.check out whether you are using the same adapter provided with the modem, if not sure check the voltage rating details provided on the modem as well as the adapter.
2.try to reset the modem by pressing the rst point provided at back side of modem keeping the modem in on condition. keep the reset s/w pressed till you see the modem lights turning off and again turning on.
3.if the lights light up normally you have the configure the modem.
4.if still having problem contact me on 9444482052 ........jammy
May 18, 2009 | Modems
SS4100 modem moved to another computer, Internet LED light not on
turn off the PC and the modem. connected the modem to your IPS (Internet Provider). using a ethernet cable in the port marked WAN. connected another CAT5 cable from any of LAN port to your PC. turn on the modem first then your PC. waite for the PC to boot up. You should have Internet access. unless you Internet Provider need to configure them modem.(dependend on who is your Internet Privider).
Oct 23, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Nokia siemens ADSL Modem c2110 USB Driver
How can i download usb driver form ADSL Modem c2110 i want to down load the siemens c2110 usb modem driver.Please help me.
Sep 29, 2008 | Modems
Modem automatically not configured ( Network Adapter)
This happens with almost all the modems and routers. You can try resetting the modem ( you can find the reset button at the back side or underneath the modem ). After the reset, the modem should get auto configured.
Thank you
Apr 29, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Paradyne COMSPHERE 3910 Modem Logo
Top Paradyne Modems Experts
Brian Sullivan
Brian Sullivan
Are you a Paradyne Modem Expert? Answer questions, earn points and help others
