Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Lost all of My Documents using SanDisk
After I purchased your SanDisk I enscripted My Document on to the SanDisk but then decided that I didn`t want it on there, so I clicked descript, but I have now lost My Document on the computer and the SanDisk. I have now lost all the photos and documents.
Is there any way of retrieving the My Document ? Please advise. Thank you.
    New Friend:
  • 53 Answers
Re: Lost all of My Documents using SanDisk
Trying going to C:\Documents and Settings\YOUR USERNAME HERE\ and see if the My Documents folder is still there.
Posted on Nov 12, 2007
0 characters
3 Points
SanDisk 2GB Cruzer USB Flash Drive has 163 documents on it and they're pretty long. I tried to put more on but it say that it cannot be put on, and that it is and error, nothing's wrong with my PC. I'm...
There isnt really a limit of the number of files, but there is a limit on space.
If you go into "my computer"(windows xp) or "computer" (windows vista/7)
and right click on the icon for your SanDisk. Choose properties, and it should give you a nice pie graph to show your free space.
If there is free space left, then it is safe to say that there is something else going on.
If not, you are out of space!
Feb 23, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i use this deice to save my material on it
plug in your device to the computer wait until its installed or detected by the computer
eg open my documents folder right click on the item or files you want to transfer to your Sandisk and select send to (send it to the name of sandisk)
or you can
open my computer > open sandisk window then open the my documents folder or the folder you want to copy and drag it over to sandisk window
hope this help
Sep 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to download a document
to copy files from PC to Sandisk you can drag and drop.
e.g. from my Documents folder use your mouse to click and hold the file you want to copy and drag it over to the Sandisk window
or you can right click the file and select send to your flash drive
from your sandisk
click start > my computer > open the sandisk and select the file you want to download you can drag file to your desktop or to any folder you prefer or you can right click the file and select copy and paste it to the destination you prefer
hope this help
Sep 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Unable to open documents saved on my SanDisk
Try using my auto-installer script for the excellent USBDeview+USBIDs using this you can ensure that the USB hub has found the device and created the Virtual CD drive used to run the U3 launcher. I only wrote the installer to make it easier for you all.
With this you can disable/enable install/uninstall the drivers this makes it way easier than using the Windows equivalent.
NOTE: If you have a conflict with the launcher you will probably get either error 1001 or 1010 for a full list of the known problems look here.
Jan 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I want to do my assignment on word.i want to save this to my u.s.b ,im not great on computers and dont no how to save or if have to do anything so my computer regodnises the flash in the first place pleze...
1. Word document .doc extension (Word 97-2003-document); this way
you can access the document even on older computers.
2. Connect the Cruzer always directly to the computer for transfers.
3. USB flash drive enough free memory (e.g. pics require a lot of memory)
4. USB flash drive has memory format FAT or FAT32
5. Have a backup on your computer on a seperate partition of the hard drive on your computer; another partition than the place where "My documents" are located. (in case you should have to restore the Operating System)
See next items how to locate your flash drive on the computer.:
Windows requirements:
When there's a drive letter conflict it can happen that the flash drive is not recognized, see:
Once you can locate the drive and know if there's plenty of memory
free you can drag and drop your document from the computer to
the flash drive: the document on the computer will stay as well.
You can also right click on the document and next select copy.
Then select (left click) your flash drive, next right click and select paste in the field of the flash drive or any map on the flash drive.
Sep 21, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a Cruzer Sandisk memory that worked before,but not anymore
If there's nothing on the drive you don't already have backed up, right click on it and select format in my computer.
If you need the files off it and do not have backup copies then you can either send it to the pros for data recovery or gamble on purchasing software that may fix it for a little less money.
Let me know which it is and I'll provide you with more details.
Sep 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Document transfer from vista hard drive to memory stick
4gb is not enough space to hold the entire My Documents directory unless you have an extremely small amount of data in it. If you take many photo's it wont be long before My Documents is too big to fit. Suggest that you back up this directory to a set of CDs or DVDs,
If you want to update a memory stick just copy My Documents from Vista to the memory stick. Vista will ask if you want to overwrite. Click [on overwrite all] and the job is done.
Jan 10, 2009 | SanDisk Open Box 1GB Cruzer Mini...
Password lost
u can recover the data with help of recovery software and scan disk gives this kind of service free.
May 04, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Stopped working COMPLETELY!!!!
Had same problem.
I wiggled back and forth the part that goes into the USB port and the drive was recognized and I could copy my files onto my hard drive.
I had this problem with a different make USB flash drive and used the same procedure to get the files back.
I think that some connection inside the flash drive works loose after a while.
I am not going to trust these drives for files storage, but only to transfer files.
Jul 27, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
74 people viewed this question
Top SanDisk Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a SanDisk Hard Drive Expert? Answer questions, earn points and help others
