Question about NetGear N300 Essentials Edition Wi-Fi Range Extender
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
  • 1,176 Answers
Hi there! why doesn't my netgear extender ask for na - smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Posted on Jan 24, 2015
  • 739 Answers
Try using the internal IP address for the unit to bring up the settings page.
Posted on Oct 26, 2014
SOURCE:
Trying to setup my netgear wifi range extender
If you look on the back of the unit, it should have in small print, the access IP address, the admin name and admin password. If you have changed it in the past, then reset it back to the default. Typically netgear use 192.168.0.1, admin name of admin, and the password is either password or netgear1. Older units may use 1234. The only exceptions are newer extenders that ask you to put in a password when you set it up, in which can you will need to reset it to the defaults and do a new setup.
Jun 16, 2016 | Uniden exi4560 2.4ghz extended range...
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
My computer tells me that I have the wrong router model but I'm sure that it's the one it is asking for. It says that NETGEAR doesn't support any other router but WNR1000 or higher and I have a...
it would be easy, first things first. you need to connect your laptop directly to the netgear router. by plugging the ethernet cable on the first slot after the yellow slot on its back. after making sure that we are connected. try to open up internet explorer or mozilla firefox. then type this numbers, " 192.168.1.1 it should ask you for a username and password. username is "admin" all in lower case and password is the word "password" itself. all in lower case. after that it would take you now to the netgear page. then try to check the leftside of the screen and look for wireless settings. make sure you would be on wireless settings. because the other one is advance wireless settings. then create your own network name in SSID. then choose security options as WPA PSK TKIP. then create your own personal password in passphrase. make sure its 8 characters long then click apply settings. then try to access it now then unplugged cable. then try to access website. it should work.
Aug 23, 2011 | NetGear WNR1000 Router
I want to connect my Ipad 2 to my WiFi network. In the WiFi settings of my Ipad, it gives me the name <dobdob> and asks me for my password which I have long forgotten. I didn' even remember the...
Hit the reset button(pin hole) on ur router and start all over setting up the router. Tape your new name and password on bottom of router so I don't forget
Feb 17, 2018 | NetGear WNR2000 Wireless Router
I have just purchased an iPad 2 and it's asking me for my Netgear password; the default password doesn't work, so I must have changed it - but I can't remember what I changed it to!
so then you can simply reset the router so to go back to its default password ...or if you want to know your recent password, simply use your computer that is currently connected to your router and is working...then follow the steps in this link http://netspace.custhelp.com/cgi-bin/netspace.cfg/php/enduser/std_adp.php?p_faqid=508&p_created=1216184248 Configuring your Netgear DG834G & DG834GV Wireless Network
Note: you dont need to configure the wireless just check the password you have setup there so you can connect your ipad wirelessly...
Thats it!! (-_-)
Jul 05, 2011 | NetGear DG834G Router
I am trying to install a netgear cg814wg wireless router manually. I am going to http://192.168.1 but its aking for username and password. I have tried admin for the username and 1234 and password for the...
You can try resetting your netgear router to default settings. the reset is button located on the rear panel of your gateway to reset all settings to their factory defaults.
Here's the router default configurations settings:
User login URL: http://192.168.1.1
User name (case sensitive): admin or superuser
Login Password (case sensitive): password
You can also check and download your router manual & user guides here:
http://documentation.netgear.com/cg814wgv3/enu/202-10297-01/pdfs/FullManual.pdf
Good luck,
Ryan
May 26, 2011 | NetGear CG814M Wireless Cable Modem...
I have a 2Wire Gateway that I'm trying to attached a WN604-100NAS to extend the range. I am getting good signal to the Access point but can't access the internet. It's asking for user,...
It's probably the user name and password of the gateway (might be printed on the router) and the IP address of the gateway like 192.168.0.1 which might also be printed on the gateway.
Aug 26, 2017 | NetGear Network WN604-100NAS Wireless-N...
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
Jun 03, 2009 | NetGear WGXB102 Wireless Range Extender...
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
NetGear N300 Essentials Edition Wi-Fi Range Extender Logo
498 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
