Question about Razer Tarantula RZ03-00070100-R2U1
O button doesn't work properly
To type an "o" successfully i have to use an absurd amount of force, making those last few words there a pain to type.
i had this problem before but razer just replaced the keyboard, didn't offer any suggestions.
Well i started having the problem with the letter 'B' so what i did was i took the key out and i placed a small square bit of tissue paper under the key now it works fine....... although this shouldnt happen with such an expensive keyboard. Im never buying a razer product again.
Posted on Jun 03, 2008
Foods to avoid with osteoarthritis
'Harmony is health', is what Ayurveda preaches. Our ancient masters and physicians knew exactly how to be hale and hearty till a ripe age! Traces of the science have filtered down the centuries, and are being revived in a big way these days in the form of herbal medicines.
Joint pain has become a very common ailment in modern age because of modern and restless life style and nutrient-less fast food, lack of proper exercise and polluting environment.
Arogyam Pure Herbs Joint care kit is a blend of rare Indian natural herbs, which are used from centuries to provide the necessary strength to joints and muscles. Herbal supplements and oil is effective pain reliever, fast acting and long lasting with blend of natural herbs that provides rapid trans dermal so gives quick relief from the pain as well as reduces stiffness in joints and muscles and removes ache.
Benefits Of Joint Pain Kit :
Arogyam herbal supplements are made of natural herbs is effective pain reliever, fast acting and long lasting with blend of natural oils that provides rapid trans-dermal which provides warm effect & helps in quick relief from the pain as well as reduces stiffness in joints and muscles and removes ache.
The herbs possess analgesic and anti-arthritic properties. By regulating the mediators of inflammation, exerts a significant anti-inflammatory activity. The herb also acts as COX-2 inhibitors and reduces the pain and inflammation without affecting gastric mucosa.
This kit really helpful for those who have pain in body like Muscular & Joint Pains, Sprains & Strains, Cervical & Spondylitis, Back Pain, Rheumatism, Arthritis, Sciatica, Stiffness, Stiff Necks, Frozen Shoulders, Back ache, Muscular Sprains and Spasm.
It soothes the joints and also helps treating levels of synovial fluid making the entire structure lubricated and easy to rotate or to move.
More than just a herbal joint pain remedies; it's a powerful all natural alternative to modern Pain Relief treatment products.
Mar 21, 2017 | Health & Beauty
Hello; Panasonic NN-H275 Over The Range Microwave - door stuck and cannot be opened. Thank you for your help. Regards, Vasily
Dear Vasilyk,
I feel your pain. I successfully repaired mine but don't know how long it will last (3 days now). Behind the touch pad there are two arms that the push button pivots on. The arm on the right was cracked where it attaches to the back of the touch pad. This allows the arm to move/give which shortens the amount of travel the button can make when you push it. After researching glues online I settled on hot glue to repair. I am hoping it holds up to the heat but from what I found out this is about the only glue that will stick to this type of plastic. I removed the back of the button and put a substantial amount of hot glue all around the base of the cracked arm and as far up the arm as possible. The arm is now stiff again and does not flex/give. I reassembled, and low and behold, it now works again. Like I said though, I don't know how long it will last and do not have a lot of faith in hot glue. I have called Panasonic numerous times to price the part but every time I call they give me a different part number with price varying $8-$40. To get the new arms I believe the entire touch pad has to be replaced. Also I could not figure out how to remove the actual button that you push without damaging it, which does not come with the touch pad. When I release it from the rear and try to push it out through the front it seeems to catch on a lip or something, did not want to damage it so gave up. The button does not need removes to repair but I think it will need removed to replace touchpad. Hope this helps.
Jun 12, 2011 | Panasonic NN-H275 Microwave Oven
When I am trying to open any saved files in MSWord, I get an error message saying "Windows cannot find example/file.docx. Make sure you have typed the name correctly, and try again." Even when I...
-Run regedit (Start menu, run, etc.) and go to this key:
-Export all the addins to a reg file (for backup)
-Then delete all of them in the registry (or one at a time if you want to
know which addin is causing the problem,
-Now try opening a .docx or .doc file in windows explorer and find that
document loads properly with out any error messages!
-now exit MS Word and open the reg file(s) you exported and import them back
-try opening a .docx file again and the problem is fixed. hope this works for you
May 05, 2011 | Computers & Internet
HP pavilion ze4300 will not shut off.
Two things you can do, you can hold down the power button, keeping it held down, should power it off. The other solution is to remove the battery, this should cause the Notebook to power down
Feb 28, 2011 | HP Pavilion ze4300 Notebook
I forgot my password in microsoft word document
forget word password?
Do not be so anxious. I know a tool which can help recover word
password,that is :Word Password Recovery 5.0
This Word Password Recovery program recovers Password to Open and removes Password to Open and Password to Modify easily for Microsoft Word of all versions from 97 to 2007.
Tip:here is another software called office password recovery 5.0 which including not only Word Password Recovery 5.0 but also other programs that can recover excel password,access password as well.
Jun 04, 2010 | Computers & Internet
I forgot my four word password
of course ! but i didn't know the reset button,i only know there is some password recovery utilities you can have a try ,
check this out : unlock word password
Apr 28, 2010 | Garmin nuvi 255W GPS Receiver
may be the integrated chip must have ceased working properly...
have you checked with your connections whether they are connected properly??
Mar 12, 2008 | Acer Aspire 5610-4648 Notebook
Control Button stopped working? How to reset?
Actually it matters not what computer you have, it's the operating system that's the problem. This is a very common fault in windows 7 and to a lesser extent XP. There are a few problem areas and solutions. Firstly, forget uninstalling the keyboard drivers or checking your files with scannow or doing malware adware checks, or ctrl alt fn buttons or installing Clipspy or going back to restore points. that's all BS and a complete waste of time, these answers are usually offered up by people who have never experienced the problem and actually muddy the waters with all sorts of number lock key board this and that answers BS answers. Put-up or shut-up! You either know the answer to the problem or you don't, and you don't if you haven't experienced it. It's annoying, frustrating and shows just how far Microsoft hasn't come.
The underlying problems with losing ctrl C ctrl V arise with eithe;r Java and/or Skype, or both. 1) Skype updates knock out the control C control V function, usually with the BS click call, it's not compatible with windows 7 and has a number of conflicts that Skype, although they claim to have patch fixed, have not solved. Even their click to call conflict patch doesn't work, an error message comes up on the download no matter where you get it from. 2) Java has conflicts with Windows 7, control panel type in Java,go to updates, if the update doesn't work you will have to remove and restore Java. It has comp 3) You can sometimes solve the problem by force switching-off your computer, without going through the normal sequence, then starting it in safe mode, which may load any missing files that have been knocked out by the aforementioned Java and Skype. Failing this, and as a last resort, you're going to restore to factory restore, but remember, this will only work for a while, until Skype updates its system and bang you'll be down again. So make sure Skype cannot update, go into Skype tools, updates, turn-off automatic updates. I hope this helps. I've had the problem 14 times and lost the will to live going through the myriad of file,sequence,number lock,uninstalls,file/malware checks BS that's out there. Even Microsoft help doesn't list the problem. James
You'll finish up going to all sorts of forums and none of the geeks or pseudo geeks have much input. Forget even the retore poin
Jan 20, 2008 | Dell Inspiron 6400 Notebook
+/- Tax button has stopped working
press C.CE C.CE RATE SET (tax ie 17.5) then RATE SET
Sep 21, 2007 | Sharp EL-334FB Calculator
Razer Tarantula RZ03-00070100-R2U1 Logo
279 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
