Drive engage handle moves. Could something have come loose from the chasis or deck?(a spring etc.) it will not go into gear.
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
SOURCE: Adjusting a craftsman dlt 3000 riding mower
assuming that you are working on a briggs engine? regardless of make what the problem is that the needle and seat inside the carb is not sealing off the fuel flow from the fuel pump/fuel tank or both......gravity feed fuel systems are the worst about flooding, the only fix will be a carburetor repair with needle and seat replacement
Hi Jack Diezi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Need the model from serial number label with is usually under the seat.
