Question about Zanussi FLE1416W Front Load Washer
Torn outlet hose
Is it easy to change
can i turn machine on its side to fit new hose
  • 249 Answers
Yes you can!!remove drawer first if it has one. it should be easy Eire--bye
Posted on Dec 02, 2007
How do I change the fuel valve on 2003 road king
Turn the handle of the fuel valve to OFF, THEN using a side cutters, cut clamp and remove hose from fuel outlet fitting at the front of the fuel valve and drain the free end of hose into a suitable container, THEN remove the elbow of the intake manifold vacuum tube from its fitting on the inboard side of the fuel valve, attach a length of fuel hose long enough to reach a suitable gasoline container to the fuel outlet fitting, turn the handle of the fuel valve to RES(ERVE), THEN using the correct hose adapter, connect the Mity-Vac® Hand Pump (HD-23738A) or similar to the vacuum fitting (To avoid damage to the diaphragm of the fuel valve, do not apply a vacuum greater than 25 inches of Mercury(Hg) to the vacuum fitting.), gently apply a vacuum of 1-10 inches of Mercury (Hg) to the vacuum fitting to get a good flow of gasoline through the valve, when the fuel tank is completely empty remove the vacuum pump from the vacuum fitting, THEN holding the fuel tank adapter, turn the hex jam nut in a clockwise direction to remove the fuel valve assembly, remove the fuel filter strainer from the valve head, remove the hex jam nut from the fuel valve and remove and discard the gasket from the valve head.
FUEL VALVE Installation
Attach the fuel supply valve assembly to the tank by threading the hex fitting on the right hand threads of the fuel tank two turns (the collar on the hex fitting faces the fuel tank), holding the hex fitting and thread body of the fuel supply valve assembly into the left hand threads of the hex fitting two turns, hold the fuel supply valve assembly so that the handle points to the left, straight away from the motorcycle, tighten the hex fitting (clockwise) to 15-20 ft-lbs (20.3-27.1 Nm), connect the fuel hose to the outlet nipple on the fuel supply valve assembly using a new clamp and HOSE CLAMP PLIERS, connect the vacuum hose to the vacuum nipple and the fill tank with gasoline, check for leaks at the fitting, turn the fuel supply valve handle ON and start the engine. No special procedures are required to start the fuel flow, carefully inspect for leaks and then turn the fuel supply valve OFF and shut off the engine after the inspection is complete.
Oct 02, 2012 | 2003 Harley Davidson FLHR Road king
Instructions for installation of amana water inlet valve 12544001
I know that seems like the incorrect part but it replaces the water valve that had 2 outlet hoses connected to it. To replace that;
Turn off house water supply to old valve and disconnect tubing
remove old valve and unplug the 2 wire connections and the 2 outlet hoses
The two outlet hoses were what was considered a Y hose..cut off semi clear plastic tubing a inch back where the 2 semi clear plastic tubes merge and become only 1
pull one of the plastic nuts off of the Y tube
slip it onto the end of the newly cut single tube
slip single tube into outlet threaded outlet of new valve and tighten that plastic nut
connect the 2 wire plugs onto new valve
remount to back of refrig
attatch house water supply to metal fitting that has/had protective rubber cap over it (oh of course remove procetive rubber cap and discard it)
turn water supply back on
it may up to 4 hrs for water to flow to icemaker so best to test by dispensing water through freezer door
Good luck,any questions or problems please reply and i'll help you,
Aug 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Change drain hose
Should be quite simple to do Eddie. Its secured by a clip onto the pump outlet undo this fit new hose resecure .Fully Watertest before use ..
Jun 04, 2010 | LG WD-3243RHD Front Load Washer / Dryer
The hose as torn along the metal ring. How do I
Hi Jim,
SmartAlec from here.
It is possible to take the end off and re-attatch (but its very fiddly and a real pain). You need to simultaneously push in the small oval pins on the side of the hard plastic part and pull the hose out. Be aware that there is 2 tiny springs inside and if they dont go back in the hose will not lock on. Once you have hose out simply cut out the bad part and reinsert to the end.
If this is too hard or some small parts go missing you will need a new hose.
You can get a new hose from
Feb 22, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Machine does not empty new pump fitted
Check the drain outlet hose for a possible blockage, also check the filter located inside the large black hose fitted to bottom of drum.
Please rate my solution.
Nov 05, 2009 | Hotpoint WMA30 Front Load Washer
I replace torn outlet hose on my Neff S4438 built
make sure you still have power going to your unit. sometimes they are plugged into a regular wall plug under the sink or you can also chrck the circuit breaker @ the panel most of the on the out side of the house
Oct 25, 2009 | Neff 24 in. S4443 Built-in Dishwasher
Installing a new waste outlet hose
You will have to remove the outer shell to access the pump.
Remove the clamp from the outlet side.
Install is the reverse.
May 15, 2009 | Plumb Pak Continuous Waste Center Outlet,...
LG washer with UE error issue
This is fairly easy to do, although you need to find some suitable foam - two pieces about 8" square and probably 3" - 4" thick.
You will also need a suitable adhesive, which could be spray carpet adhesive, copydex, or silicone sealant.
Turn off and unplug the machine, "walking" it out slowly if it's under a counter. Do not strain the water hoses too much.
Undo the few screws along the top at the back that holds the lid on, then slide the lid back an inch and lift off.
There should be some foam buffers in there already - but may have fallen off. Retrieve them if they have, but fit your bigger ones instead to leave maybe a finger width gap each side of the drum.
Make sure any springs on the top you can see are ok while you're there.
Once fitted, refit the lid and screw back, then push back the machine from very low down - check hoses are not squashed, and the outlet hose is ok.
Turn on again.
Jan 02, 2009 | LG WM-1832C Front Load Washer
Torn Hose
You can use evo stick glue.
But normally once it has ripped open it will do it again so probably best option fit new hose.
Nov 03, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Zanussi FLE1416W Front Load Washer Logo
24 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
