Pressure cap on top will not close completely with clamp
Not sure what you mean??
A little more detailed information, even if you don't know proper terminology, some greater description will allow us (someone on this forum) to assist you.
If you have a filter similar to the picture of the one above that accompanied this post, then there is NO cap! There is no cap that you can open or close. Can't tell for sure what it is you are referring to when you say "pressure cap"?
Then you mention something about the Clamp?
I will take a stab...
Did you just remove the " MultiPort - Dial Valve" from the top of the filter? And now you are trying to reinstall it?
And is it that you can not get the valve to go all the way down onto the filter tank? And the two flanges: the one on the valve is not meeting the one on the tank? And the "Clamp" just can't grab both of the flanges to tighten the valve to the tank?
Is this your problem?
If so:
You have a problem!!!
The plastic "Stand Pipe" from the bottom Lateral Assembly is sitting "Too High" and the valve has bottomed out on top of the stand pipe.
Thus not allowing the valve to go down any more, leaving the gap you just can't close.
What may have happened: when adding the sand to the tank, the following bags after the 1st, allowed the lateral assembly to rise and instead of sitting on the bottom of the plastic tank, it is now sitting on some sand, raising it? Even an Inch or so, will now create a situation where the Multiport filter valve will be too high and not allow the Sand Filter Multiport valve to seat properly.
Fix = Remove the sand and start all over again.
Remember: Very Important:
After the 1st 1/4 of the 1st bag is poured, stop and adjust the pipe - "BUT NOT LIFTING IT", to be centered with the hole.
Good Luck
