Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
For cleaning of hardwood floor onething must keep in mind using of too much wet solution on dirt and then rubbing with cloth can destroy shineness of the floor and makes it dull looking. So it is always best to use vacuum cleaner for removing dirt particles from the floor.
This is one of the advantages of hardwood flooring. With the use of vacuum you can remove other products like hair and nails. For alternate way one can use marketed hardwood floor cleaners. But I will suggest to use vacuum cleaner for cleaning purpose.
Yes, you can use the Bruce hardwood floor cleaner. I've used it many times to clean up after jobs. It brings a nice shine to the floor and is designed for either a hardwood or laminate floor. Hope this helps.
I would recommend using another cleaning method developed for use on hardwoods. It seems to me like even if you replace the wheels, eventually they will wear down again, causing more damage to your floors. Check home depot, ask them what the recommend. Hope I could help.
