What brand and model phone is it? On an Iphone you start at the main screen, flick the bottom of the screen to view a menu and then press the flashlight icon.
A common problem with torches and flashlights, especially led types of certain price ranges, especially those constructed of aluminium.
Most such torches use a push switch that has a point contact that soon becomes incapable of providing the perfect contact that is needed for low voltage low current applications. The materials used usually isn't the best for the job.
Aluminium casings are prone to oxidisation which is an electrical insulator.
Whether it can be fixed depends on how far it can be dismantled, the design and how handy you are.
A torch should ideally have a switch with a wiping or self-cleaning action and be hard wired with high quality nickel-plated brass or copper internal components.
It is many decades since such a torch was generally available at reasonable prices so a compromise might be made by spraying the inside of a new torch with a silicone spray or WD-40 and repeating whenever the batteries are replaced.
FLASHLIGHT BATTERY INSTALLATION FOR TORCH: Open the Torch Battery Door located on the bottom of the Torch. Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline batteries are recommended) into the torch compartment. Be sure the polarity (+ and -) matches, as marked inside the battery compartment.
FLASHLIGHT: Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position. FLASH/BLINK FUNCTION: Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink. BULB REPLACEMENT: Rotate the Torch Cover anticlockwise to hear “click” then pull out the cover, remove the old bulb. Then pull out the torch cup, remove the blinker’s old bulbs and reinstall new bulbs. Replace the torch cup, then reinstall a new bulb. Replace the Torch Cover.
You can directly connect your water cooling argon torch to the tank, but the pump electric wires must be connected in accordance to the switch, when you press the switch you start to weld and the pump is on, release you stop welding and the pump is off, rather an electrician to do the connection for you
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes
1. Torch switch is activated (closed) before user turns power on.
a. Release torch switch.
2. Faulty torch switch
a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON
1. System is in SET mode
a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Niyat,
If you go thru the Menu - Phone or Extras you would find an Option of Torch. Use this temporarily. Then you would also find an option for the Navigator button to be used for various programs. Here select the particular switch you want to use for torch and for this select the torch item and save. Now whenever you press this particular button the torch will come on.
