Question about Acer TravelMate 4021WLMI Notebook
Power switch always in on position
Power switch automatically turn on after two three seconds of turn off of laptop
  • 117 Answers
This is power switchproblem or os problem remove your hard disk and turn on same probelm is there it is a mother board problem
Posted on Mar 06, 2008
Principles of Operation
The driver seat module (DSM) is on the controller area network (CAN) communication network. To support several vehicle subsystems, the module permits intermodule and diagnostic tool communications.
The DSM controls the memory driver seat and the passenger memory power exterior mirror. This passenger memory power exterior mirror feature allows the driver to program personalized mirror positions. Once the driver stores a mirror position, the driver can recall the setting by pressing the corresponding memory switch or by using a programmed remote keyless entry (RKE) transmitter. For additional information, refer to Section 501-10 .
How to Diagnose Controller Area Network CAN
Driver Seat Module - Memory Seat
The power driver seat, power outside rear view mirrors and power adjustable pedals are controlled by the driver seat module (DSM) only when the vehicle is equipped with the programmable/recall memory option. The DSM is located on the driver seat track.
This system allows automatic positioning of the driver seat to 2 programmable positions.
  • A power driver seat position can be stored at any time. The driver must move the seat to the desired position using the driver seat switch assembly. The driver must then depress the memory SET switch which activates the memory SET switch light emitting diode (LED). Within 5 seconds (before the LED goes out), the driver must select a memory position. Memory 1 is selected by depressing memory switch 1. Memory 2 is selected by depressing memory switch 2.
  • If no memory switch input is received within the 5-second time limit, the operation is aborted and the memory seat position switch (set switch) LED is turned OFF. This also occurs if one of the following inputs is received during the 5-second programming limit:
    • Driver seat control switch
    • Memory seat position switch (set switch)
    • Power adjustable pedal switch
A programmed seat position can only be recalled when the transmission selector is in PARK or NEUTRAL with the ignition switch in the RUN position. A position may be programmed at any time.
Easy Entry/Easy Exit
The driver power seat easy entry/easy exit feature can be enabled/disabled. Refer to Section 418-01 or the owner's literature.
This may need to be done with a scan tool
Apr 24, 2017 | Lincoln Cars & Trucks
Unlock Child lock on nissan if the lock is on and dont open from outside
All doors lock automatically when the vehicle speed reaches 15 MPH (24 km/h).
? All doors unlock automatically when the ignition is placed in the OFF position.
The automatic unlock function can be deactivated or activated. To deactivate or activate the automatic door unlock system, perform the following procedure: 1. Close all doors.
2. Place the ignition switch in the ON position.
Within 20 seconds of performing Step 2, push and hold the power door lock switch to the position (UNLOCK) for more
than 5 seconds.
4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
5. The ignition switch must be placed in the OFF and ON position again between each setting change.
When the automatic door unlock system is deactivated, the doors do not unlock when the ignition switch is placed in the OFF position. To unlock the door manually, use the inside lock knob or the power door lock switch (driver's or front passenger's side).
The automatic door unlock function can be changed using the Vehicle Settings in the vehicle information
Sep 30, 2016 | Nissan Pathfinder Cars & Trucks
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Apr 20, 2011 | Geha Primo 1400 Shredder
My wrless is not going to b turn on on windows 7 nd xp plz give me the sedation nd support for it
Critical battery switches off the wireless network card to preserve power. Motherboard seems to log this status but when re-connecting to mains power the card does not receive power again. Uninstalling the driver and getting Windows to re-install automatically upon re-boot does not work.
Charge up the battery whilst the computer is running. You can charge it to a substantial level, say, above 25%. Disconnect mains power so that your laptop is running on battery only. Set your wireless switch to OFF (this is usually to the left position, away from the orange indicator). Now run your computer down to the critical battery level again (perhaps overnight). In the morning when you press the power button, the 'CHARGE' indicator (looks like a lightning bolt) on the front of the laptop should flash quickly, indicating that there is no charge in the battery. Remove the battery from the laptop's underside. Wait a couple of seconds, then press and hold the power button for 30 seconds. Keeping the battery off the laptop, reconnect mains power. Boot up your PC. When at the Windows desktop and all your startup programs have finished loading, switch your wireless on (to the right position). You should now have a blue light, and wireless should once again be working. You can now re-insert your battery. You might have to setup your wireless network connection again as mine seemed to be 'lost', but at least hopefully the main problem is now fixed
Feb 08, 2011 | Computers & Internet
I changed the battery on my 1996 Honda Accord LX and now the car won't start. I have power, but the LED on the extreme left of the dashboard blinks 3 times repeatedly, the turn indicator sound clicks and...
Do you have a remote door lock? Try clicking your doors open and closed. You can turn the key to the start position three times and re-set the security that way on some Acura/Hondas. My son has had to turn the key to the start position and change the position of the Automatic gear shifter - back and forth. I think it has something to do with the Neutral/Park safety switch on his '93 Legend.
Make sure the ground wire is good. The security and starting circuits depend on a ground wire going to the engine from the battery/transmission area. It may be loose or not getting good contact.
Honda/Acura has kept the old fashion battery post type batteries. Always wire brush the inside of the cable connections and the battery posts.
Oct 23, 2010 | 1996 Honda Accord
Ice maker not dropping ice, the switch is on, and the ice has been in the tray for quite some time now
POWER ON DIAGNOSTICS TEST MODE When the ice maker is first connected to power and the thermistor temperature is 50°F or more, the control will initiate a “Power On” test before entering the freeze cycle. The test will consist of the following sequence:
1)Turn on the motor until it reaches home position
2)Turn on the water valve for 1/2 second
3)Turn on the heater for 1/2 second
4)Verify that the feeler arm was in the “in” and then the “out” position.
5)Verify that the motor was not in the home position and then in the home position.
6)Verify that the motor does not remain on after being turned off.
7)Proceed to the freeze cycle. SERVICE DIAGNOSTICS TEST MODE During the first 15 seconds that power is first applied to the ice maker, the Service Diagnostics Test mode may be entered. The Service Mode is entered by pushing the feeler arm in and out three times within 15 seconds. (only three times). There will be only one fill cycle (5.1 second) in the service diagnostics mode without the waiting period for the mold to “pre-chill”. If the ice maker has already started a harvest cycle and the arm is moving, it may be impossible to start the service mode. (since the NORMAL cycle is already started). While in the “Power On Diagnostics” test mode, the “Service Diagnostic” test mode can be initiated and will override the “Power On Diagnostics” test mode. This ice maker has no replacement parts available and is not intended to be repaired.
Jan 26, 2010 | Refrigerators
Where is the dome light switch on a 2006 Pontiac Torrent
on your headlight switch turn dash lights up till "click" dome light comes on
Aug 07, 2009 | 2006 Pontiac Torrent
1993 Cadillac Deville Phantom Codes
ECM Output Cycling
This mode can be initiated after "E.9.5" is displayed on the "Fuel Data Center". The display of the "E.9.5" can be reached by depressing the Hi button while Code ".7.0" is displayed. The ECM output cycling mode, Code "E.9.6." turns the ECM's outputs on and off. To enter the output cycling mode, proceed as follows;
The engine must be running.
Turn the cruise instrument panel switch to the on position so that the cruise control outputs will cycle.
Turn the engine off and within two seconds, turn the ignition on.
Enter the diagnostics and display Code "E.9.5".
Depress the accelerator pedal (throttle switch open) and release it (throttle switch closed). The ECM output cycling mode begins as the display switches from Code "E.9.5" to Code "E.9.6."
It is possible to leave the ECM output cycling mode at any time and return to ".7.0" by clearing the ECM and BCM codes. If the display does not advance to Code "E.9.6", refer to Code "E.7.2" of the switch test.
The output cycling mode will end automatically after two minutes of cycling and the display will switch from Code "E.9.6" to Code "E.9.5".
The outputs will cycle on and off every three seconds until the two minute automatic shut off occurs. The only exception to this three second cycle is the cruise control power valve which cycles continuously. If additional output cycling is desired, recycle the throttle switch.
Oct 13, 2008 | 1993 Cadillac DeVille
Seat Belt Chime
Belt Minder Deactivating/Activating
1. Before deactivating/activating the belt minder, set the parking brake.
Place the transmission range selector lever in P (PARK) (automatic transmission) or the NEUTRAL position (manual transmission).
2. Place the ignition switch in the OFF position.
3. Close all the vehicle doors.
4. Unbuckle the driver safety belt.
5. Place the parking lamps/headlamps switch in the OFF position.
1. Turn the ignition switch to the RUN position. (Do not start the engine.)
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt nine times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
4. Turn the parking lamps/headlamps ON then OFF.
5. Buckle then unbuckle the safety belt nine times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable the belt minder if enabled.
7. The following sequence of events confirm the belt minder is enabled:
-flashing of the safety belt warning belt lamp four times per second for three seconds
-three seconds with the safety belt lamp off
-flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation that the belt minder is disabled.
9. After confirmation, the deactivation/activation procedure is complete. user_offline.gif
Apr 02, 2008 | Car Audio & Video
Acer TravelMate 4021WLMI Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
