What are the ignition switch connections on a bobcat 720? The manual gives me the wire colors, but the connections are too blurry to accurately tell what wire goes to which terminal. It is a 4 terminal switch with no real terminal designations marked on it. Any guidance?
It requires 3 wires to start 2 to feed power to ignition and 1 to acativate starter , signal wire ,if you use a test light and find power and make up 2 sets of jumper wires once you touch the red wire to any 1 wire you should hear starter ingauge but it wont stay running till you connect yellow and black wire , once you know what wires do what its easy. that's the way I remember it im sorry if this is confusing if I was there it would take 5 min.
SOURCE: I want to hook up my XM radio receiver to tun off
using a test light or meter locate a fuse that does not have power when the switch is off - xm should require only 5 amp fuse - no more than 10 - pull fuse to test which side the power is coming in and hook into load side of fuse-
SOURCE: 97 S-10 WON'T CRANK. STARTER, CLUTCH SWITCH, AND
could be neutral safety switch or passlock system. Try resetting the system by leaving the key in the ignition for 10 minutes before trying to start.
SOURCE: which wire is constant power 4 the radio, and
1991 Ford F150 Truck Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Red or Black
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
This should help you with more then just the constant power wire, good luck.
SOURCE: Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
