The home page only have the volume (loud and soft) at the bottom, and the face page has the calendar, date and time. Then it turns itself off.
This will work on if you are using windows XP. If you are using any other OS please revert back.
Switch ON the PC, boot the PC
in 'Safe Mode' by continuously tapping F8 button after you switch On until you
get the Safe Mode Option.
Let windows boot in Safe Mode and log in to windows. Go to 'Start'--->Programs--->Accessories--->System Tools--->Click
'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and
click Next
Now you will find one Month Calendar window with Dates below, go to
the previous month by clicking the '<' sign in the upper left hand
corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are
facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System
Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
If you feel that, my answers have helped you getting
solution to your problems then please give a vote.
Thanks.
'System Restore'
click Next
reboot.
'System Restore'
click Next
