SOURCE: Needs driver for ATP3
Hi Saburine
http://www.teksale.com/computers/computerparts/listings/ALTEC%20LANSING%20ATP3%2027W%20RMS%20BLACK%203PC%20SPEAKERS.htm
here you can get the complete drivers.
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
SOURCE: no sound
check the port to which u have connected ur speakers. And also install proper driver
SOURCE: Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
