D-Link DIR-655 Wireless Router Logo
v
vuong tran Posted on Oct 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the password for my router
I want set up the key net work for my router . I mean the password
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Oct 25, 2014
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1015253
Points
21773
You can find the info here:
http://support.dlink.com/emulators/dir655/121/Wizard_Wireless.html
and here:
http://www.dlink.com/-/media/Consumer_Products/DIR/DIR%20655/Manuels/DIR655B1manual070312v23pdf.pdf
I have not open wi fi wire less net work . But wire less net work LED is open
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
How to set up password for internet
Welcome to Fixya.
If you want to set a passowrd (Passphrase) we can access the Wireless Settings Page of the router to obtain the information needed.
To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security you can set a security either WEP, WPA, or WPA2 and under the Security Mode you will see there Network Key (Wep/Wpa Key) or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
6helpful
4answers
Forgot the password i tried so many times but incorrect allthe times
You will want to try
username: admin
password: admin
username: admin
password: 1234
username: admin
password: password
If these dont work you will want to reset the router back to defaults.
1helpful
I am having trouble resetting a password on netgear to accomodate an IPAD
Hi rammjoe,
I'm not sure if you're reffering to the password of the router or the password of the network or Network Key. You don't need to worry listed below are all the sters on how to obtain both password.
If you want to obtain the password or security on your router you need to access the Wireless Settings Page. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Go to the Wireless Settings Page and look for the Network Key or Passphrase.
You can also reset the router to its factory state but you need to keep in mind that all settings will be back to its default settings. To reset the router press and hold the small reset button at the back of the router using a Pen or a Paper Clip for 15-30 seconds.
If this works dont forget to say thanks. Thanks for using Fixya.
Cant remember the wep on my net gear wireless router
Use a computer that is working with the router, wired or wireless.. Then login to http://192.168.1.1 or http://routerlogin.net
enter admin for username and password for password. Once logged in, click Wireles settings on the left panel.
You will see Security option, this should show WEP if the router is really using WEP, then you will see key 1,2,3,4 boxes underneath, whichever is selected and has the series of characters, that series of characters is youe WEP key. Make sure not change any settings as it will affect other wireless devices currently connected.
3helpful
2answers
There is no wireless connection and it says that the password may have been changed. It also asks for the key to be entered. What is the network key? How do I change it? How do I restore the assigned...
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here
for step by step instructions
2answers
How can i find my network key password
log onto the router and under the wireless security tabs change your password to a new one and you should be able to use the wifi after that with the new password , also you will have to reconnect any pcs that use the wifi to the router using the new password
1helpful
How to change the password of a wireless router
Log into your Router go to Wireless Settings somewere in this fiedl you will see document.write(sec_key) Security Encryption (WEP) Key document.write(ba) . Type the password you want in Key 1.Click save settings your done. Now when someone trys to ocnnect to your Wirless net work they need this password. If you want to Change the password to log into your router you need to go to Admin settings on your router THATS IF YOU HAVE THAT OPTION TO. Most routers logins stay what they call factory settings..
2answers
Dont know net work key
ok, goto 192.168.1.1.
acoording to the manual of a simlar router,
you need to set the SSID to name the network
then create a Pre-Shared Key, now insert the cd on the machine you wish to connect to this network , if you have no CD give me the model number of the Wireless stick then hopefully we can get a driver, if you insert the hardware it may not pick a driver or it may pick a driver that will not work correctly so disconnect the wireless stick, install the driver then when prompted insert the stick , the driver will be on the CD otherwise give me the model number or goto google and search on that model
3answers
Cant get may psp and my wii consoles to work
This is the password to your wireless network.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
