Question about SanDisk Sansa e260 MP3 Player
Only one audio output working - not stereo!
I have a Sansa e260 that has stopped providing an output to the left channel of audio.
When I plug in my phones (and I've tried multiple sets that I am certain both earphones work), I only get an audio output to the right channel and none to the left.
Is this repairable and/or worth the effort? There's a LOT of wma's on there that I'd like to save.
  • parker32 Jun 16, 2008
    Also have the same problem but I have used it very little. Of course it is after 1 year.
  • 626 Answers
It is the actual headset jack on the device. It wears out from plugging and unplugging the headset.
If its less than 1 year, call SanDisk and they will replace it.
Otherwise, if you are inclined, you can replace the internal headset jack.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Posted on Nov 11, 2007
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
May 07, 2015 | RCA Televison & Video
No sound on one channel
Have you reset audio to factory defaults? If it does not clear up, try plugging the audio outputs to a stereo's auxillary inputs and see if both channels come through.
If neither approach works, the fault is going to be in the audio processor/board.
If the external stereo does work with both channels, and the TV only has sound on one channel, it may be failed speaker, it may be broken wire, corrosion, a failed amp chip (the outputs to the stereo are tapped off at a point in the audio chain before the power amplifier.) or a fault in the audio processor.
Oct 09, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
Nov 11, 2009 | Car Audio & Video
My sansa e260 will not play with my jvc kx810 car stereo connected thru usb
The Sansa doesn't play through the USB connector. Plug the stereo into the Sansa's headphone jack instead.
Jan 13, 2009 | SanDisk Sansa e260 MP3 Player
Audio from go46
sounds you have 2 channels set on stereo maybe not mono ?
Aug 07, 2008 | Yamaha GO46 Sound Card
Connecting Sansa e260 to factory car stereo
there's hardwire kits ( and tape deck adapters. sirius might work if only audio jack is needed
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
it happen a couples times on my 4th pair
dont roll yours earphones around your mp3 player
me too they was all playing on the left side
Mar 25, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260 doesn't even turn on
Had the same problem, blue light no screen, took the cover off found a small black rectangle block not completely pushed in. the block is located on the right center on the part above the battery and right behind the screen.
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
Hi, I have the same problem but sometime is the left channel & sometime the right channel. I tested multiple headphones and it's alway the same problem. FYI the problem begin after a firmware update. With the original firmware the problem never append. It start with the firmware ver. 01.02.15E. Today I have downloaded the new firmware version (01.02.18E). I hope it fix this annoying bug. Bye
May 01, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
120 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
