Question about ASUS P5LD2 Motherboard
Ide problem HI I am have a problem with my ide and sata drives they seem to be having some conflick. I have the sata drive as the boot and ide as the spare. sata drive is connected to sata2 and when I connect the ide drive in the Sec Eide it works then locks up when connected to Pri Eide computer wont boot. I am not sure if its a driver problem as my cd stop working. Not sure if the ITE8211 IDE Driver will help if I can find it. hope this info helps. Thanks In Advance (Salty)
  • cockspurman Nov 15, 2007
    But thats how I already had it setup with the problem I am getting..thanks againg for you reply...but prob still there. :(
  • tweakit Feb 23, 2008
    p5ld2 booting from 80gb wd ide to XP. trying to install new 400gb wd data drive (no raid) using wd lifeguard tools to set up new drive. It doesn't recognize sata drive. tried both windows and dos versions.
Just set the sata as first boot hard drive in your bios then connect the other drive :- )
Posted on Nov 13, 2007
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
Oct 01, 2014 | Systemax Computers & Internet
Can't get ECS PM800-M2 to boot to SATA drive.
You need to make sure that your SATA drive has an Operating system on it. It can't boot if it only has a data drive.
Feb 19, 2013 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Sometimes it boots to my SATA hard drive, sometimes it doesnt
Dear friend you i think you have to operating system in to hard drive.. Please... format the IDE hard drive... if IDE hard drive is Primary hard drive then go to the BIOS, In BIOS go Boot Sequence you may see there Hard disk Priority option.. Let set Sata hard drive as first one.. Then your computer Boot from sata Harddrive... thanks...
Please do this first.. Set sata as first hard Drive from BIOS Hard disk Priority Option.. then Format IDE Hard drive..
Thanks Sumon.. i think it will solve your problem..
Mar 27, 2009 | Computers & Internet
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Sata and IDE hard drive
hi there,
yes your motherboard would allow this .. once you configure in the bois your boot drive being the IDE drives ....the operation of the other drives should be a breeze ...
Apr 27, 2008 | ASUS P4S8X Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mar 22, 2008 | Abit NI8-SLI Motherboard
Sata & ide darddrives
Hi, All dual drive capable boards read the SATA first, just make sure both SATA & IDE are enabled in the BIOS, load your O/S as normal this will load on the 1st SATA and the others will be auto detected as drives D and E, the IDDE will be E by default. Regards mistyman
Sep 22, 2007 | Soltek SL-75FRN2-RL Motherboard
ASUS P5LD2 Motherboard Logo
197 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
