SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
SOURCE: material will not feed across
This machine has a pressure regulator on the left side.You should look to see that it is not loosened. When you lift up on the presser foot it should have resistance.
Then look at the feed dogs to see that they are moving, Set the stitch length at 4 and turn the hand wheel. The teeth should move towards the back of the machine. They should also be slightly above the needle plate as they go back and below the surface of the plate as they come forward.
If they don't rise above the plate , remove the needle plate and clean between the slots of the teeth.
sewman7
SOURCE: I need an instruction manual for a New Home model SW
I remember stocking that model, the only place you may get one is www.sewingonline.co.uk/instructions or www.sewusa.com
SOURCE: New home sewing machine model HF106 have been
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
