I have a hobart c44a model dish machine. As the fills up, when the first float engages it blows the 3fu fuse. Where should I look first. I also disconnected the first float and the fuse did not blow.
1.Loss of water pressure due to pump obstruction. Check for any obstruction at the pump intake.
2.Strainers clogged causing inadequate water supply to pump.
3.something may be inhibiting free movement of the low water float; remove any foreign object from around the low water float or its magnet.
If your water temp. gauge (on piping) is showing 180 but the digital display is only reading 125 deg. then I would remove the water temp sensor from the rinse piping on back upper part of machine (It is a small probe with wires coming out of it). Clean probe with emery cloth and put it back in to see if that changes the display. If it doesn't then you may need to replace the probe.
