Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin G+ MIMO Modem Router
I replaced my AOL supplied modem with the G+ MIMO modem router. Cannot run AOL software anymore but can access internet through Internet Explorer and AOL Explorer. Cannot access any microsoft websites though. Wireless connections are fine but cannot access microsoft websites.
Found an error in the modem configuration - one number mistyped! Unfortunately the print on the installation instructions was so small the typo went unnotticed. Maybe I need to go to the optician (or I may just be getting old...)
Posted on Nov 11, 2007
    Sergeant:
    Champion:
  • 306 Answers
Unistall AOL, clean out temp files, clear history, go to control panel, internet options, Connections tab, remove anything in the dial up and virtual private networks....should be good to go.
Let me know.
SOURCE:
Does the belkin G wireless router require a wired PC or can it just be connected to the cable modem for wireless use?
You may need to connect it via USB to initially set it up, refer to the instruction manual.
While in use, any wireless router only needs a power supply and connection to a modem for internet access. It will not need to be wired (permanently).
Jan 04, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router will not connect to the internet. Shows local access only. I don't have the installation software.
Make sure the cable between your internet modem and your Belkin router is secure and in the proper ports..
Are all the lights on your internet modem lit up? If not, you have an issue with the internet modem.
Nov 19, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless G+ MIMO ADSL2 + modem routerF5D9630
You need to find out what settings need to be changed in the router to communicate to the new modem. Etisalat should have some type of instructions on how to configure it...Does the IP address get obtained automatically or is it manually configured. Does the modem require authentication..like a password. Did they replace the modem or just upgrade the system? You may just ahve to reset the modem and router to get reconnection. Most routers use the IP address of 192.168.0.1 or 192.168.1.1 to get to the router settings control panel. Just enter one of these addresses on internet explorer and a screen should ask for a password. The default password is usually ADMIN but consult the routers manual for instructions. Once you are in the router control manual you can configure the router to work with the new system.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Modem light blinking and no internet in the wireless router. but when i run a cable from my modem to my computer, internet works....but when i rund the cable from the modem to the belkin wireless...
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Apr 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Problems with Belkin Wireless G Plus MIMO Router
- Nope, it is not possible, you may need an Access Point to do it.
Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Problems setting up Belkin wireless G+ mimo modem router/usb network adapter
It sounds like the router address is wrong or you are not connected to the network.. Guessing you are using Windows XP or Vista. Go to the DOS prompt (http://www.computerhope.com/issues/chdos.htm) then type ipconfig. This will bring up details on your network (see example below).
IPv4 Address. . . . . . . . . . . : 192.168.0.4
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
You should see default gateway address which is the address of your router ie 192.168.2.1 in your example. If this is not shown you have not connected to your router properly. If it shows a different address use the address shown to try and access your router. HTH
Nov 14, 2007 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
115 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
