Question about Motorola Mobility L6 Cellular Phone
Game display when game start it not display on the screen it looks black when exit game mode the game menu lookson screen for second
  • ishrat Nov 11, 2007
    be cause its a reliable to all
    Brigadier General:
  • 7,752 Answers
Try a master clear and reset and see if that helps are if it is a game that you loaded on to the phone try deleting it and reinstalling it
Posted on Jan 19, 2008
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
On my Brother MFC410CN Printer Message reads Unable to clean I have followed TroubleShooting instrctions and it still appears
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error,
replace machine.
press stop to exit if needed.
(http://www.fixya.com/support/t250171-brother_mfc_215c_unable_clean)
Oct 06, 2008 | Televison & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Clean unable 50
  • Not knowing which printer you have ,here are 2 solutions:
The printer must be reseted:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
  • OR
  • Machine off
  • Switch on the machine while holding down the "menu"button until all the leds are flashing on/off. Now you are in "maintenance" mode.
  • Press 80
  • Press the "mono start" button several times until you see "purge: xxxx"
  • Press "2783" in order to reset the purge counter. You will see: "purge:0000"
  • Press the "stop" button.
  • Press "99" to exit the maintenance mode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Office Equipment & Supplies
Brother 165c clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide. clean unable 46
Error 46 on Brother printers The printer must be reset:
  • Press 99
OR Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Thanks, Joe
Feb 12, 2011 | Brother DCP 165C Compact Color Inkjet...
Unable to clean
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
Mar 30, 2010 | Brother MFC-5840CN All-In-One InkJet...
Wii black screen
The following fix should help users who do have problems with some virtual console games for the Nintendo Wii that display only a black screen after starting them while the sound remains normal. This does not work in all occasions but should work if you get the Wii menu when you press Home and works only for games that received an update for the interlaced mode.
Try out the following to see if this fixes the issue. Start the game normally until you see the black screen. Connect the Nunchuck to the Wiimote and press Home to see the menu options. Now press A + 2 + Z together which should result in a short “ping-like” sound.
This should have activated the interlaced mode. Leave the menu and you should see the normal game screen and not the black screen anymore. To change the mode again press A + 1 + Z using the same method as above
Nov 20, 2007 | Nintendo Wii Console
Motorola Mobility L6 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
