Question about Canon i250 InkJet Printer
Canon i250 not working
My Canon i250 has 2 new ink cartridges (colour and black) and I have had the printer heads cleaned and checked by a technician and they are not clogged. Yet, it is still not printing. The ink comes out so faint the paper is almost blank. This problem came on suddenly, the printer has worked well for 3 years. First it stopped printing in colour and now the black won't print either. Any suggestions other than buy a new printer?
  • 3 more comments
  • Bill634 Dec 02, 2007
    My Canon i250 also just stopped printing. It goes through all the motions as though it is printing but the paper comes out blank. It was working fine before this suddenly happened.
  • mikearena3 Aug 31, 2008
    My Canon goes through the motions but the paper comes out blank. I have a Mac iBook if that matters.
  • lucy_kale Sep 14, 2008
    my black ink has stopped working i changed all of the ink cartridges, it's so annoying!
  • dzmiller Dec 01, 2008
    I'm having the exact same problem. My color cartridge won't work. I've tried several different ones, Canon brand AND store brand. No good! Any solutions to this other than going out and buying a new printer?
  • Anonymous Jan 28, 2009
    My printer works normal but the page comes out blank
Posted on Oct 15, 2008
My canon PIXMA iP 4000 does'nt write out the colours, only black.
Use the Canon software to check the ink-levels in the COLOUR cartridge. If empty, replace it.
Use the Canon software to run a few "print-head-cleaning" cycles, to unclog any ink-jets that are not spraying ink onto the paper.
Feb 22, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Canon ip3500 does not print black but colour ok ... whats up ... how to fix
1. this could be a clogged print head at the black cartridge. the head needs cleaning or the jets have clogged ports and cannot pass ink due to hardened ink.
This may require a print head replacement.
2.If you have recently place a new cartridge in the print slot check to see if you didn't leave the protective tape on the cartridge.
Apr 20, 2010 | Canon PIXMA iP3500 Printer
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have an Canon IP4000 printer that is not printing black text. It is printer colour but not black. I have replaced all the ink cartridges but only colour is working. Please help!!
pretty familar with that printer and if you have new cartridge check the head cleaner. If you clean the heads a couple of times that might unclog the black cartridge. Check inside your settings. I know you can turn the color completely off with that model but am not sure if you can turn the b+w off.
Jan 21, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Canon i250, black text won't print, but ok with nozzle check
Canon i250. Instructions on this website solved the problem of flashing green and orange lights, but now the black won't print. Changed ink cartridges, but still no print. Did a diagnostic nozzle check, and the black DID print. What do I do now?
Oct 21, 2009 | Canon i250 InkJet Printer
All colours and black print faded. Black is a
Assuming that you are using original Canon cartridges or a brand of Compatibles that you have used before.
If print results are blurred, colors are faded or not printed correctly, the pint head nozzles are probably clogged.
Follow the procedure below to print the nozzle check pattern, check the print head nozzle condition, then clean the Print Head. You may have to do this 2 or 3 times.
If printed ruled lines are misaligned or print results are otherwise unsatisfactory, aligning the Print Head may improve print quality.
Caution Do not rinse or wipe the Print Head and ink tanks. This can cause trouble with the Print Head and ink
Note Before performing maintenance
Open the Top Cover and make sure that all lamps on the ink tanks are lit red.
If not, see Checking the Ink Status and take an appropriate action.
Increasing the print quality in the printer driver settings may improve the print result.
Sep 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
My Canon i455 will not print black ink
Hi , try to clean head until the black color will complete visible .clean also the ink retainer or tank replace with clean absorbent.
May 09, 2008 | Canon i455 InkJet Photo Printer
Canon i250 InkJet Printer Logo
1,138 people viewed this question
old marine
old marine
