Question about HP LaserJet 1020 Printer
Ghost images of the same printed page
Whenever I print a page, the text repeats about a third of the way down. While it is a very light image it is still very visible, and makes the bottom 2/3 of the page difficult to read. I run the clean process and changed the setting to 1200 but all to ni avail.
  • 1 more comment
  • Anonymous Nov 25, 2007
    I have the same problem. I have HP cartridges. The printer is brand new!!!!
  • morillo8 Nov 04, 2008
    I also have the same problem. I'm using a brand new laserjet with the original toner cartridge.
  • Robertya May 26, 2009
    After using the printer for 1 year (hardly 200 pages are printed), I am facing the same problem. I assume a new cartige is able to print 3000 pages without any problem but the printer failed in this case.
  • HP Master
  • 1,113 Answers
Probally your print cartridge, Replace it.
It has a rubber blade that whipes off old image that gets worn, sometimes not near as often it from fuser section..
To find out more see
http://www.fixya.com/support/t243749-words_copied_multiple_times
Posted on Nov 11, 2007
  • 3 Answers
How far is it? could you measure from the top of one to the top of the next. This would help narrow down which part is causing the issue.
Posted on Jan 22, 2008
Replace the Q2612A cartridge. You are probably using a cheap remanufactured cartridge. Use only quality remanufactured cartridges where they replace Drum, wiper blade and doctor blade or buy an OEM cartridge.
If the printer has been heavily used it could also be that the fuser is on the way out.
Hope it helps - i see hundreds of these types of printing issues per year.
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
My HP 1022 is double printing the text down the page. The repeated printing is very light and fades as you go down the page. there are also some broad light gray horizontal marks down the page. I cleaned...
Observed ghost image:Primary level: Replace with another cartridge & check the qualitySecondary level:Teflon sleeve faulty, replace it if available or replace fuser assm.( Technical skill required for attempt secondary level)
Oct 03, 2011 | HP LaserJet 1022 Printer
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
May 14, 2010 | Brother MFC-7820N Laser Printer
Ghost printing preceeding page images and or text
1.Most likely is the fuser assy, depending on what your page count is. 2.Could also be your toner cartridge especially if it is a reman
Dec 08, 2009 | HP LaserJet 4345mfp Printer
I am getting a ghost image of what I am printing repeating down the center of the page.
i would say ghost image is more likelly your imaging drum.
some printers have the imaging drum built into the cartridge some have it separate.
i would say try another cartridge
also don't trust remanufactured cartridges if you are concerned with print quality.
Apr 24, 2009 | Samsung ML 1430 Laser Printer
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
HP LaserJet 1020 Printer Logo
1,760 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
