Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius model wm62
Machine not turning on fuses ok . no electricity goin to machine
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Posted on Dec 04, 2007
Hi, how can I purchase a door hinge for a Hotpoint WM62
WM62 does not look like a valid model #.
Look for a metal tag ( usually under the lid ) for the model # then go here:
http://www.searspartsdirect.com/partsdirect/brands-products/Hotpoint-Parts/Washer-Parts
find your model and click the shop parts button.
May 20, 2011 | Washing Machines
Hotpoint Aquarius WM62 bearing noise how to change it
Hello,remove all the surround screws from around the door glass then gently lever the 2 halves apart,remove the old hinge,and re mount the new one along with the plastic bearings refit the screws,refit the door to the front cabinet.
Thanks
May 23, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The washing machine won't drain the water, the washing itself looks covered in fluff so now thinking system is blocked with fluff oh crikey what can I do please oh please Hotpoint aquarius WM62
drain screen or hose is most likely clogged. That is usually the case when they don't drain. Newer machines are really tempermental this way.
Jul 10, 2009 | Washing Machines
Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Jan 12, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1000 WM62 motor problem?
hotpoint aquarius 1000 if motor is connected (plastic plug in socket) RCD earth trip trips in main board when washer is switched on, trips as soon as water starts to fill.
Oct 16, 2007 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
485 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
