SOURCE: subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted. Most likely through the service menu, if units under warranty you can call Akai. For further structures.
SOURCE: vizio flat screen tv
I have run into this before with many vizios. Your problem most likely is with the power supply. You can just try to unplug the TV and plug it back it. This most likely wont do anything but it is always worth the college try. Leave it unplugged for about 15 sec. If nothing works i recomend looking into the return policy from the place you bought it from. If you didnt purchase an extended warranty then you have a year from the manufacturer and that warranty will cover a problem like this. I do suggest taking your tv to a licensed technician with a problem with this. I dont recomend doing exploratory surgery on this TV. One question for you. Is this a plasma or lcd tv and does it make any clicking or tapping noises?
SOURCE: cant get the subtitles of the screen been pressing
Are you sure they are subtitles rather than closed captioning (if it is TV rather than DVD, it is closed captioning)?
If it is closed caption, pressing subtitle won't turn them off. If there is a button that says "Closed Caption" or "CC" press it. If not, press menu and look for the CC option (it should be under video or audio depending on the TV). Turn it off.
If you are watching a foreign language movie on TV (not DVD) it is likely hardsubbed (you can't turn the subs off because they are burned into the video).
Testimonial: "thanks m8 but my tv is linked through a reeview box and cant get subs of."
SOURCE: My 7 month old hit
It could be on the cable box also but for the tv you usually have to access the menu then the setup then languages for most tv's
on some tv's there is also a button labeled CC
