I saw this question hanging around since yesterday, so thought I would take a crack at it. I remembered that Jeff has access to data where grounds are, so thought I would try. I see he has answered.
Jeff Armer Aug 18, 2023
It's not a ground issue, driver side headlamp grounds at same place (G201) underneath the dash .
Headlamps
The headlamps may be turned on two different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the OFF position, for automatic lamp control (ALC). During ALC, the headlamps will be in day time running lamp (DRL) operation in daylight conditions, or low beam operation in low light conditions. The LH HDLP and RH HDLP fuses, supply battery positive voltage from the under hood junction block to the left and right headlamps. The circuit continues through both low and high beam lamps, then back to the under hood junction block. The low beam and high beam circuits continue to the headlamp switch. The low beam and high beam circuits also provide the body control module (BCM) with both low and high beam inputs. The headlamp switch includes the dimmer switch and the flash-to-pass switch. When the headlamp switch is placed in the HEADLAMP position a path to ground is provided. Ground is provided at G201. Depending on the position of the high/low beam switch, either the low or high beam circuit will now have power and ground.
G201
On the left side of the I/P, near the fuse block
I found this, as Jeff says, not a normal ground near the light unit because it is computer controlled.
What is the ground wire for the headlight on a 2000 Pontiac
JustAnswer
https://www.justanswer.com > Pontiac Problems
Mar 21, 2017 - What is the ground wire for the headlight on a 2000 Pontiac Grand Am? It only has three wires. two blue and one red or pink.
1 answer · Top answer: Hi, my name is ***** *****
body control module controls the ground for the headlights, ...
