Question about HP Compaq FP5315 15" LCD Monitor
Lcd monitor failure
When turning computer on screen remains black. Sometimes if I unplug power lead and then plug in again it will come on, other times it will flash on momentarily and then go black. Also sometimes get a repeated 1 sec rising high pitched whine, but screen still remains black. I am trying another FP 5315 monitor and that is ok.
  • Pambia Feb 18, 2008
    I have an HP vsd flat monitor - 14 months old, it just became black. Sometimes when you turn it on, it will work for a little while and then became black again. I ttried another working monitor and the same thing happened. What could be the problem?
  • 23 Answers
Your monitor need to be service so take it to service center if you are in mumbai you can call for service
Ashok
9322133048
Posted on Jan 21, 2008
Dell 1905FP powers up but screen goes black after a few minutes
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Feb 14, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
Monitor - Display problems
There may be a power supply failure in your monitor
May 30, 2013 | ViewSonic VA712 17" LCD Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
It won't turn on -
hi there, it sounds like your monitor isn't receiving power, check the power cable in your monitor is connected and not partially unplugged. Second, if that doesn't work, try looking at your plug and make sure that is plugged in. If that doesn't work, you may have to buy a new monitor or give it to a friend that can repair it.
Jan 19, 2010 | NEC 1760VM (Black) 17" LCD Monitor
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
173v flat lcd black screen
I've had a similar problem with my 173v monitor since I bought it a few years ago. When I start my computer, Mac or PC (I've connected it to both), the screen remains black and the green power light flickers once a second, almost like it's twitching - it's different from the blink it makes when the computer isn't turned on but the monitor is. Like kronem, I have to unplug the line from the monitor to the computer, wait for the monitor to register no input, and then plug the monitor in again before it displays anything. I've never figured out a way around the problem - I hate it!
Feb 21, 2008 | Samsung SyncMaster 173V 17" Flat Panel LCD...
HP Compaq FP5315 15" LCD Monitor Logo
1,137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
