Details as described above. I still haven't used enough characters.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
SOURCE: Take the back cover off a LCD Television
Take out all screws around the outer edge and the smaller screws just above your video conections and dont forget the 6 large screws for the mount in the center. It should just lift off.
SOURCE: How do I remove the case from a X37sv-Naga 37 in.
There are no clips, just make sure to remove the speakers and the stand.
SOURCE: Need to remove the voltage inverter for a Samsung
the inverter comes out by levering out ( NOT LIFTING ) of light holders start at top ( THIN SCREW DRIVER ) will do TAKE YOUR TIME
Testimonial: "Thanks that worked. Unfortunately they all came up ok accept for one in the middle of the board where one of the lamps broke off. Bad. Now what?"
SOURCE: How to remove external case of Samsung LTN1765, after 2 screws removed.
Hello
I've all the details for your TFT LCD monitor. It has all the details about its service, disassembly and reassembly methods [with illustrations], schematic diagrams, voltage charts, adjustments to chasis, voltage chart etc. But I can't send you that document by this site, as it does not allow me to upload PDF files by it. Moreover, acording to newly hoilsted FixYa site, I'm not allowed to send any PDF files to customers. If customer want to get it, he have to purchase one amoung my advertised service on FixYa.
So if you purchase one amoung Samsung service advertised on Fixya, I can send you all the documents by the link provides by Fixya between us. If you are interested, do the rest. OK.
SOURCE: Hi I have a Philips 42PF7520D/10 which also fails
Use a WD 40 to be sprayed on the screws so as to lighten it and then try with the correct head and length. Now coming to the fault , this is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
