Van wouldn't start. Battery terminal was corroded and changed terminals. Now dinging bell when door is opened and lights on wont shut off even if vehicle is shut off and doors closed.
SOURCE: 2005 dodge durango anti-theft system
have you tried starting the car ,if not lock the car, open with key manually and try and start
SOURCE: 2000 dodge neon won't start.
look everyone !!! i am not the only one who has this problem , but I
found the answer on my own.... iI hope this can help others . If you
have to replace a neon engine you must do these thing if you want it to
start.
<br>
Lower vehicle and perform camshaft and
crankshaft timing relearn procedure as follows:
² Connect the DRB scan tool to the data link
(diagnostic) connector. This connector is located in
the passenger compartment; at the lower edge of
instrument panel; near the steering column.
² Turn the ignition switch on and access the “miscellaneous”
screen.
² Select “re-learn cam/crank” option and follow
directions on DRB screen
Most people don't have access to this scanner <but it must be done> I used a snap-on cost 3000 but have the reset feature
Thanks you all for your help.
SOURCE: 98 Dodge Durango no electrical power
When the armed Vehicle Theft Security System (VTSS) senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed after the battery is reconnected.
The alarm can be disarmed by locking the vehicle and turning the drivers door lock to the lock (arm) position. Wait a few minutes then unlock (disarm) the drivers door and the vehicle should start.
If the VTSS has been disabled in the high-line Central Timer Module (CTM), the VTSS feature must be re-enabled using the Chrysler DRB scan tool. The clicking you heard was probably from the CTM located behind the glove box.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: dash lights blink, radio fades, alarm bells go on and off.
try your belt this happan to me when i drive my speedo go's up and down see if your belt on good
