Http://cdn2.blocksassets.com/assets/ozito/ozito-product-manuals/a5HtlQpnPoZO1ml/LT4-1000-Manual-Ed7.pdf
Hope this helps you. Good luck.
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
SOURCE: stihl fs trimmer line fitting
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
If you need more help, let me know.
Jim
SOURCE: how do i install a new trimmer line ie plastic
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
SOURCE: Please advise how to fit a new cord into the line
See pages 13 and 14 of this Homelite manual:
http://lawnandgarden.manualsonline.com/mdownloads/dad45d75-2e75-4b21-815a-6e17c5148060.pdf
