PHONE MEMORY FULL
SOURCE: phone saying memory full when its not
is your phone set to save photos to the phone memory or to the memory card..? that might be the reason why it is saying memory full. due to the phone memory being full. normally on symbian phones, there is an option settings to change the default location for saving photos and video. if you make it the memory card, then hopefully that will solve your problem. cheers
SOURCE: Phone memory full-Nokia N91 8GB
Go in to the message program and delete all sent and received messages. also check the drafts and outbox. Check that photos are being saved in the big disk not the phone memory. Move all photos and music to the big disk.
When you have done this. With the phone still turned on, pull the battery out. This will cause the phone to do a restart. Then you should be ok.
SOURCE: My phone is very slow and freezing alot. also two
memory full-it is caused because the phone uses some internal memeory for ram like bluethooth connectio,wifi so please reset your phone to factory settings
system error-this is due to the firmware plz upgrade it to the latest version by connection to the pcsuit and plz do have an antivirus in your mobile
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
SOURCE: "Memory is full. Please delete some messages."
Initially go to Internet explorer
select menu
select tools
select options
choose the memory tab
delete all cookies and temp files
If there are more messages in send items delete that too.
Hope this helps you
SOURCE: I cannot get SMS due to FULL MEMORY. I have enough
you have to go to settings and go to saved memory and then hit memory card not phone memory
