Question about Acer Aspire 5100 Notebook
Keyboard & mouse are dead
Hi people,
glad to be among you all....
Neither the Kboard nor the mouse are working, in such way I can't even hit F2 to enter the Bios.
My laptop is 2 yrs old and it worked fine until now....
I guess it has to do with ACPI settings,since I tweaked a bit with it just to set the proper "standby" time and all....
Any advice?
thanks for all
paolo
  • 20 more comments
  • Tipster Nov 15, 2007
    My Acer Aspire 5100 is also 2 years old. The Keyboard and touchpad stopped working. As I was using it, it began to lose track of the mouse. Now I cannot even use the F2 function to start in safe mode. NONE of the USB ports recognize external mouse or Keyboards. The mouse does light up but does not contrrol the pointer. Cannot get beyond windows sign in screen. Tried running computer with and without battery - made no difference.
  • Anonymous Nov 17, 2007
    here is an up-dating report:
    since I can't enter the bios to set my pc booting from cd, I tried to remove the hd to force the machine booting from cd.
    This done, I've inserted a live cd version of ubuntu and, voilà, the linux based OS started up and keyboard and mouse worked fine....;-))
    Nothing to do as I set the hd back into the laptop, btw :-((
    Guess it's not a hw prob, neither a connection disguise...
    Strange to know how many people sorted out with the same issue...
    cheers
  • y_live Nov 30, 2007
    same problem
    i'm living in a developing nation now, so i doubt if there was power overcharge
    any of others from places with bad electricity?
  • Anonymous Dec 05, 2007
    i have the sam notebook and had the same problem.
    tried everything, the solution posted here seemed to work.
    Hard power-off (hold the power button until the laptop turns off)
    Unplug the AC adaptor
    Remove the battery
    Plug in the AC adaptor
    Hold ctrl and turn the power on. You should arrive at a black screen.
    Hard power-off again, then turn the power on.
    Of course it was not that easy, when i went to reboot it took 10 tries and an hour before the black screen went away....but then my computer was back.
    Wish i new why it worked?
  • jetonrexhepi Dec 08, 2007
    same problem
  • ipedrojm Dec 26, 2007
    Hello everybody. I has the same problem of all of you....It happened I think almost 2 months ago (is my sister's laptop) and I can't do anything with the laptop. I was spending a lot of time searching on the Internet this kind of problem and it seems to be usual in this model of acer laptop. And also I realised that the problems with the laptops was ocurred on the begining of October since now. So strange...I just want to know more about the Nyago's solution because I don't understand well how can he fix the problem... I mean: I never reach the black screen when I am holding the Ctrl button and then turn on the computer.
    Thanks for all of you and sorry for my english.
  • ruswilks Jan 02, 2008
    I have the same problem (except its a 3100 not 5100) however when trying the solution (Ctrl held when powering on) the laptop still boots as normal (runs a checkdisk then proceeds to login screen). Have trying briefly holding Ctrl and holding all the way to the login screen, never ends up with a black screen- any ideas?
  • leblin Jan 11, 2008
    I have the same problem on an Aspire 3100. I'm unable to get a black screen by pushing CTRL key while booting up, but i was able to get a black screen by pushing both CTRL keys + ESC and booting up, also ALT+F10 got me a black screen. I left the computer on for over an hour on this black screen but didn't fix the problem.
    I've also confirmed that I can boot into a linux live CD and the keyboard + touchpad are working, but the problem persists once I reboot.
    I've even tried flashing the bios. this was very tricky without a keyboard. i had to create a bootable CD-ROM to automatically run the bios update. Didn't help the problem at all though.
    I hope someone has a solution for this. The laptop is only a few months out of warranty.
  • Dprotech Feb 05, 2008
    I have the same problem with 2 aspire notebooks both with the ATI Radeon XPress chipset and Turion 64 processor. Models are Aspire 5103 and Aspire 5043. Both stopped working 2 weeks ago with the exact same problem. Keyboard and Touchpad not working. Cannot even get into BIOS by pressing F2. External Mouse and Keyboard doesn't work either. Have emailed Acer tech support and awaiting answer. Have tried above solutions to no avail.
  • brownman1000 Feb 14, 2008
    I have the same problem with an acer 1502. Tried the fix but instead of booting into windows it does a disk check?????
    What's up with these $$^&%%$£ laptops.
    Tony
  • Anonymous Mar 29, 2008
    OK. ( or not ok) Keyboard and mouse do not work, on Acer Aspire 3100.
    PC Doctor says that the motherboard is fried....NOT SO!
    Do this : remove power supply. remove battery. hold power button down on lifeless laptop for one minute. hook up power supply only. turn on.
    I had to hit the windows key before I saw life return. The task manager appeared. Then a control F, then the arrow keys worked. A function F2 unlocked the mouse. This came from Acer tech support over the phone.
    TRY THIS FIRST. Acer charges 400 plus to replace bad boards.
  • Anonymous May 06, 2008
    same problem on my 5100. all i had to do is remove main battery, remove power adapter, wait 60 seconds. then power up with ac adapter only. xp did a chkdsk, and when it finished booting into xp, everything was working. thanks
  • Steve May 07, 2008
    I just can not believe this, it seems that ACER has a real bug, whether MB or sowtware. I have installed two boards up to this point and still have no KB or mouse. Can not enter BIOS setup either. I was amazed at the rapid response from ACER tech support. $440.00 dollars for a new MB. How many do I have to go through? I have tried several solutions found as well as variations. I've run out of patience. Any help would be appreciated, you know, another brain....
    Thanks
    SMP
  • Anonymous Jun 21, 2008
    Reply to May 29 post :
    Power button must be held down for one minute with no power supply or battery hooked up. Also the keyboard and mouse can be locked with a function key combo. Watch for this.
  • babyherman10 Aug 05, 2008
    I have a emachine T1742 home computer that has windows XP home in it.I whipped the hard drive and was about to reinstall my windows XP home the keyboard and the mouse stopped working.Know I can't boot from my XP Home disk to finish installing windows help.My computer keeps beeping when I have my keyboard plugged in.When I unplug my keyboard the beeping stops.
  • boco4 Aug 10, 2008
    I can't get out of "safe mode". What a pain! No phone support.
    Restarted computer
    F8 - "troubleshoot "safe mode" ..... nothing works
  • arvee227 Feb 08, 2009
    I have the same problem with my Acer Aspire 5100. It was working fine until yesterday. I have tecken the keypborad off and everythinig is firmly connected
  • jonttuv Feb 21, 2009
    My Aspire 5100 is broken very bad. It doesn't respond anything! Please help! USB's, Keyboard, and mouse doesn't work. It's like USB doesn't give any power. I'm buying PCMCIA usb's if that will work.
  • old_boy_20 Feb 25, 2009
    I have an Acer Travelmate 2440. KB, Mouse and USB just stopped working. The system boots up, windows loads and after that no response from KB or Mouse. Tried everything. Disassembled everything, took out the CMOS battery hoping to reset the BIOS options, but no luck. Tried the CTRL holding and powering up procedure, but nothing. Any other suggestion.....
  • darkange176 Mar 17, 2009
    my kb and mouse not working and all usb doent work please help me?
  • AcerSucks99 Mar 29, 2009
    Weak solutions all FAIL, Acers website support steers clear of this problem, you loons posting those other FAILED links stop being retarded, you must for for Acer, no one is that stupid.
    NOW does anyone have a solution that works?
  • Anonymous May 22, 2009
    Acer no mouse , no keyboard people:
    The PCMCIA slot will work.
    You can use it to install a usb card
    and plug in an external mouse and keyboard.
    Clumsy, but at least you have access.
I just fixed this problem by doing the following:
Remove the battery
Posted on Nov 29, 2007
  • Kenny Smith
    Kenny Smith Oct 13, 2014
    i did that now im stuck on black screen?
Posted on Feb 05, 2008
  • Dprotech Jan 06, 2009
    Just following up on this problem. I am a computer retailer and have sold 5 of these acer aspire 5000 series notebook with the AMD/ATI chipset. Guess what 4 of the 5 notebooks have now been returned to me with the exact same problem as all of you, where the USB ports and the Onboard Keyboard and Mouse stops working. The operating system will continue to boot but without any controls these Notebooks are useless.
    All these products failed after a year of service and are all passed their manufacturer's warranty period. However the 80% rate of failure is grounds for a class action suit. Now I know you guys don't buy 5 of these at a time, but believe me, this deserves an explanation from Acer. I would certainly like to give my customers some of their investments back.
    please post the serial number of your machines and detail of error when replying to this post, and I will compile this into a formal letter to Acer North America and if I fail to get an answer I will have lawyers follow up on it.
  • 3 Answers
Uplug laptop, remove battery. Hold power button down for one minute. Start laptop without battery. This action dumps static charge. IF this doesn't work, you can try using the pcmcia card.Plug in external keyboard and mouse to the card.
Handicapped, but at least it is useable.
Posted on Mar 15, 2009
My wife's 5100 lost keyboard, touchpad and usb. I used a pcmia card to attach an external keyboard and mouse. This let me access Device Manager and reinstall drivers. All work fine now. (Pretty sure original problem occurred because of overheating.)
Posted on Mar 01, 2009
Yeah Ctrl works, pc beeps when u keep pressing button and starting pc, when u put pc in standby u can awake him with any key on laptop keyboard... Just turned off yesterday my aspire 3100 and today keyboard+touchpad is dead...
Posted on Oct 05, 2011
I have the same laptop, and it has many problems. The mainboard is ****. Advice: when it starts to fail, try using it as a desktop, with external keyboard, mouse, monitor if you have to, don't invest any more money in it because it will fail again, and don't buy acer any more.
Posted on Jan 06, 2009
Hi,I have a acer aspire 3100 Mobile AMD sempron Processor 3200+(1.6 GHZ,512kb L2 Cache) ATI Radeon Xpress 1100 laptop,when it boot up to XP ! it shows normal desktop but i cant use my keyboard not even toch pad,i tried above solution by :
Remove the battery
Hold ctrl and turn the power on. You should arrive at a black screen(after few seconds i hard power-off again)
Then turn the power on(without inserting the battery).
But no success, can anybody tell me is this a hardware fault or i have to dig with the solution u guys mentioned above or is their some changes to the above solution...
thanx in advance.
Posted on May 28, 2008
    New Friend:
Same problem, keyboard, touchpad and USB are dead...I can only control darkness of LCD - over keyboard, thats funny. Made CD with BIOS update, without needness of keyboard, its updated, but doesnt help. Tried start UBUNTU operation system - only from CD and keyboard worked...no comment. (I think, that is BIOS driver problem - UBUNTU uses own drivers), so looking for BIOS to replace...
Posted on Nov 10, 2014
    New Friend:
You know what Sucks? I just got a brand new, out of the box, fresh off the line, Acer Desktop PC and the keyboard and Mouse have frozen 13 days after installation. So it is NOT just Acer's Wonderful c-laptops that are screwing up its all their peripherals.
Posted on Jul 24, 2013
I have the same problem w/my old Acer, the keys broke and I have been using a wireless mouse for over a year, but just the other day, it stopped working and so did everything else, no mouse nothing, without a mouse you can't do anything!!!!
Now I'm worried I bought a new Acer back in March, I sure hope it doesn't do the same thing. I don't think it's because of heat, all our laptops sit on fan pads to keep them cool.
bw
Posted on Dec 05, 2011
  • 846 Answers
If you've tried the software restore it still won't respond i wouldassume there is an issue with your palm rest. Since both keyboard and mouse are unrepsonsive, it looks like just a connection issue. If you're out ofwarranty, somebody has to open the Laptop and replace the part. The partis available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Posted on Jul 26, 2010
From stevenaddy.
I don't know about hard power offs, but if the keyboard don't work it don't work. At least in my case. I finallyy put in another MB, 4th one and success.
Thanks to all who gave inputs.
Posted on Aug 14, 2008
Ok if the the key board is not working how can control button work?
Posted on Aug 13, 2008
  • netsky469 Sep 21, 2010
    You right in 99% man :) ... as someone told FN key sometimes still works
    ok ok guys a Just solved
    this solutions You give me is piece of ****
    I tried fix this problem several hours
    I tried update bios with autobootable cd bios but problem was still ...
    and then in fourius i just start press all FN key 3 times each
    after that ... EUREKA keyboard live again !!!
    so I think there is hiden FN keyboard lock or just FN config is sucks and not exacly same with images on the buttons
    i got little same problem with Lenovo keyboards
    same keyboard but FN keys different
My 18 month old Acer Aspire 5100 has been exhibiting similar behavior; a few minutes after bootup, I cannot use the mouse (touchpad) or keyboard (laptop). I tried plugging in exteral keyboard and mouse devices, but it made no difference. I don't use this computer that often, so I left if for a day or so and it seemed to be working again, but then started with the same problem. I tried to offload my files and much to my surprise, even after the KM locked up, the files continued to copy. I am beginning to suspect this is possibly an overheating issue, as when I leave the computer off for a significant amount of time, I can use the KM for a few minutes, but if I try to reboot right away, it only takes a moment or two before the KM don't work.
I tried this solution
Remove the battery
Which worked, but only when I held both the CTRL and ESC keys during bootup. I've been using the computer for almost an hour now and the keyboard and mouse are working.
Posted on Apr 01, 2008
I have the 5100, this happened, I was under warranty and they replaced the motherboard, good as new until now. Not even one full month later and I am frozen again. In order for the computer to be replaced it has to happen 4 times!! I don't understand why it is happening. I had it for a year with no problem at all.
Posted on Mar 03, 2008
I had the same problem and took it to 3 different places, new motherboard fixed the problem
Posted on Jan 13, 2008
I have an acer 5100 just the usb ports quit, there is no legacy usb support in bios and holding the ctrl and pressing start dam near crashed it completely. Don't understand why advise is no good. I do know that you can reset by disconecting the power at the source remove the battery hold down the start button count to 20 releace, wait ten minutes plug power in and start.
Posted on Mar 13, 2008
    Problem Solver:
  • 29 Answers
Hi Friends,
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Posted on Jul 20, 2010
  • 63 Answers
Are your keyboard and mouse USB? If so, legacy USB support needs to be enabled in the BIOS. Try using a PS/2 keyboard and mouse as a temporary workaround until you get the BIOS settings down.
Regards,
Javabytes
Posted on Nov 12, 2007
Left mouse button not working
Hi Jim,
Was it working before.?
Have you checked the settings in the Mouse System preference?
If you connect that mouse to another computer, does it work ?
If not.. it's a dead mouse.. how old is it.. If it's less than a year Apple will gladly exchange it.. If it's more than 5 years... it's dead
Apr 30, 2013 | Apple iMac Computers & Internet
I got a cordless kboard how do i set up
I got something that you will probably need to set it up. Kindly go here http://www.logitech.com/repository/1408/pdf/25311.1.0.pdf. There you will find the step-by-step instructions on how to setup you mouse and keyboard.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 17, 2011 | Logitech Cordless Desktop MX3200 Laser...
My F2 Sleep (hybernation) key doesn't work when I hit it on my HP keyboard? The sytem is only one week old. The Sleep key never worked from the get go. Thank you for you rassistance.
Try [Fn]-F2
I had same problem here, then just tried alt-F2, ctrl-F2 etc until I found the right combo. Looks like the [Fn] key is what activates the other built-in Fkeys. In other words, "it's not a bug, it's a feature".
Sep 07, 2010 | HP P2360AA Keyboard/Mouse
Toshiba Equium 2000 does not recognise USB keyboard
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Feb 18, 2010 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
I cannot use my keyboard and mouse. Something is wrong with my devices
Make sure the keyboard is working in bios. When you boot the computer hit f2 or Del. key to make sure the keyboard is working. Also make a note that the keyboards light blink while turning on the pc.
If you are able to go to BIOS that means the keyboard is working fine.
Boot your computer in safe mode by tapping F8 key while the computer is booting. Select safe mode and check if the keyboard and mouse is working in safe mode.
If it is working in safe mode. Do a system restore to a date where everthing was working fine.
Please revert with the result of above .
Sep 01, 2009 | HP Computers & Internet
Keyboard keys not working when you hit them.
Open a notepad using mouse and then check if u can type in notepad.
Shut down and reboot the system and boot in bios by hitting F2 or F10 or Delete key on keyboard. If u are able to boot in bios ,reset bios.If unable then disconnect keyboard and try different port to connect.If issue persist replaced keyboard.
Aug 17, 2009 | HP Computers & Internet
Wireless keyboard not working
well,the problem is small,,first check with a different set of batteries on the keyboard,after tats done,press the connect button the wireless receiver and after 5 sec on the connect button on the keyboard,if the connection to the mouse gets disrupted then press the connect button on the mouse.the last step u can try changigng the usb port of the receiver,,,i beleive there is no other troubleshooting steps to this issue,,if still no go,,call up tech support and replace the whole set
best of luck,,keep me posted ,giv a good rating
May 19, 2009 | Computers & Internet
Resetting a wireless mouse
the usb connection and the mouse should have a button both need to be pushed usually the usb connector first then the mouse, or shut down the computer then restart. let me know if this helps.
Mar 31, 2009 | Logitech Cordless Mouse
I can't make double letters
well thats not good.same thing with my little brothers kboard.the letters O & L r stuck 2 gether though...
Jan 25, 2009 | Labtec Wireless Desktop Keyboard/Mouse...
New Gateway KEyboard problems
If u installed anything incorrecly then the computer will prevent the mouse and keyboard from working, try plughin in a diffent one and see if it works, if not, ur keyborad and mouse might have fried
Jan 04, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
22,670 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
