Question about Garden
I need cub cadet 2140 ags wiring diagram with an Onan elite 140 motor
  • 1,169 Answers
See if this will work( from the 2000 service manual.
i need cub cadet 2140 ags wiring diagram with an O - 25249664-fmbov4hi54zjavdnh3ojgjxv-2-0.png
Posted on Oct 23, 2014
5 Suggested Answers
  • 109 Answers
SOURCE: Cub cadet 2145 (Onan engine)runs the battery down
One possible problem is the voltage regulator is out. To test this, start the engine and put a d.c. volt meter on the battery, if the voltage readout decreases as the mower runs, replace the regulator
Posted on Jun 29, 2009
SOURCE: 96 cub cadet 2140 with cummins onan 14hp
I have cummins cub cadet Onan Elite 140 engine shuts off after about 20 min and won't restart for half hour.
Posted on Jun 06, 2010
  • 111 Answers
SOURCE: I have a cub cadet
The starter solenoid could be going out. This is a piece of the electrical system and if you are not familiar with it then I would take it into the dealer and have them fix it. Otherwise you could be shocked or burned if something went wrong.
Posted on Mar 30, 2011
  • 5370 Answers
SOURCE: cub cadet 2140 with a
You will have to remove the ground wires from the ignition module and retest for spark using a spark tester not the plug as the plugs may be bad themselves. If you still have no spark you will have to replace the ignition module.If ignition module is checked ok, then disconnect the small yellow color wire leading to the module . That particular wire grounds the module to shut the engine off. If it starts and runs, then that will lead you into either a safety switch /wire or ignition switch.---------- If there is continuity to yell wire, that means wire is getting power.The yellow wire "provides a ground to KILL the engine". Either when you turn off the ignition or when a safety switch becomes enabled. Now that you know the wire itself is sound, you should try unplugging the yellow wire to see if that restores spark. If it does restore spark, you will need to find out whether it is a defective ignition switch or one of the other safety switches (which give the yellow wire a path to ground also) that is causing the module to stay "grounded". Also check the wire leading to seat switch.If its getting shorted, then there will be no spark problem.---------- Check out.This should help.Keep updated.Thanks.Helpmech.
Posted on Apr 12, 2011
Cub Cadet won't turnover.
Try boosting it directly from the battery and see if it will turn over now. I had that problem and found my cable on the ground side had corrosion in it. I put new cables on and is ok now.
Jun 18, 2018 | Cub Cadet Garden
My Cub Cadet 2140 with Kohler 140 elite engine has constant power to starter.. Unhooked ignition and relay checked reg rectifier and still 12 volts to starter???
Starter switch could be making constant contact causing power to be on all the time. Disconnect the hot wire off the switch and see what happens. Then hook it back up and try the other wire and check voltage as you do this to both wires.
Aug 23, 2017 | Cub Cadet Garden
My Cub Cadet with kohler 140 elite has constant power to battery.. checked ing switch and relay.
Im looking for a wiring diagram for cub cadet lt1040 riding mower
https://www.partstree.com/parts/cub-cadet/mowers-lawn-garden-tractor/104-cub-cadet-garden-tractor/wire-diagram/
wiring diagram for cub cadet lt1040 Google Search
May 22, 2016 | Cub Cadet Garden
I have a cub cadet 2140 with a onan 140 series motor. The problem is that I can turn over the key and all I get is a clicking noise. I can do this several times before the mower will start. The battery...
Mar 27, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
1,740 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
