Question about HP P5750-69001 - System Board/P4 Motherboard
Beeps in the motherbaord
Once switch on the computer in my HP PC where P5750-60001, iam getting display , I Changed the porcessor as well as the memory module , beep is unique type. please assist me
  • 134 Answers
Re: beeps in the motherbaord
Click here to learn what the computer beeps mean, let me know how many beeps you hear. It could be a video problem or a faulty memory module, try reseating your video car and memory modules also.
Let me know what happens
Posted on Nov 11, 2007
0 characters
3 Points
No display cpu fan and led indicators are working fine.Iam using RoHS Compliant N15235 motherboard.Can u tell me what will be the fault?
I don't know much about these things but I understand if everything is ok there is an audible beep shortly after switching on, at least all of my pc's have beeped. According to my motherboard manual there is all sorts of beeps as an aid to fault diagnosis.
As there is no display perhaps there is something wrong with the graphics card. It looks as though your motherboard has on-board graphics and it might be best to use those initially with a known good monitor.
Jun 25, 2016 | Motherboards
Whn iam starting my pc it get start but there in no display and no beep in pc tell mi why this problem coming
Try to check if your memory card is still working properly remove it from it's slot and try to clean it. If you have a spare memory card try it make sure that it is also working. A start up with no beeping sound indicates a memory card or a motherboard problem. Sometime low power voltage output also is the reason. Try to deal with your memory card first. If your memory card is working fine, try to see if your power cable inside your motherboard is connected properly, if it does, sad to say you have a failing motherboard sir, and needs a replacement. Hope this would help you, have a nice day.
Sep 20, 2011 | ASUS A7S266-VM/U2 Motherboard
I don't think we should directly blame it to the Power Supply, but I can't make it very thorough since you didn't mention whether the system can boot up or not even without display or not. Can you hear beeps or fans' sound when you press the Power button on the computer? Have you tried the monitor on another computer? or have you tried another monitor on your computer? or have you check the video cable? Have you checked the Ram? Have you checked the power supply unit (smps)? Have you checked the Power cables? and many more. If you haven't done all these, do one by one and replace the necessary components respectively and keep trying, if nothing's worthy, then it must be the video card on the motherboard which I would recommend installing a new video card (add-on graphics card). It's also possible that there's problem with the Motherboard bios.
In most cases, the Ram is the cause, once you replaced or checked Ram, you'll be able to find out what exactly is the root of the problem.
These are the basic steps of troubleshooting a display problem.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 15, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
Unable to boot my PC
reset the cmos ... then change it back to 100 ... Dont try and overclock your porcessor without knowing the right settings ..sometimes you have to increase the volts to cpu and ram
Oct 13, 2009 | Intel Motherboard
Motherboard Gygabyte GA-7N400 Beeps and Won't Start
It might be worth testing it with another power supply before you throw it. With modern motherboards requiring multiple voltages (and multiple power connections!) it is quite common for a faulty PSU to prevent start-up.
Hope this helps.
Jun 13, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Display problem
give me details your machine power up properly, its giving beeps continously, if not check your connection of motherboard or remove your ram and check it, its giving a beep
Oct 15, 2008 | Intel Motherboard
Motherboard does not startup
Please remove the CMOS battery & reinstall it after 15 minutes.
Jun 28, 2008 | Gigabyte GA-6BX7 Motherboard
Please help
if your cpu can't heat so your mobo vrm circuit fail ic no: adp3168 near by cpu
Mar 29, 2008 | Intel D845GVSR Motherboard
P4i45gv asrock motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
HP P5750-69001 - System Board/P4 Motherboard Logo
252 people viewed this question
Top HP Motherboards Experts
 Mike M
Mike M
Level 1 Expert
Are you a HP Motherboard Expert? Answer questions, earn points and help others
